POLL: What year, how many miles and what have you replaced in your 4th Gen???
Old Sep 22, 2001 | 05:38 PM
  #41
NZ Max's Avatar
Originally posted by AltiMAX
'98 GLE 15K
Replaced the ECM last Wednesday. It had been throwing a code for the check engine light to come the morning after I bought the car. Good thing it was covered under warranty,
I claim 4th gen with lowest miles
I think someone has 3k....
Old Sep 22, 2001 | 11:11 PM
  #42
AndyXXL's Avatar
'98 GLE 15K
Sup man, did you get clear bumper lenses already?
Old Sep 23, 2001 | 07:08 AM
  #43
MadMax66
Re: '98 98k miles...
Originally posted by The_quorum
3 sets (all 4) tires, 4 sets brakes (and no I can't get rid of the squeal), 1 set rotors, 2 front calipers, 2 sets sparkplugs, 2 PCV valves, 1 air filter swap to a K&N panel, 2 fuel filters, 6 headlamps, 2 tail lamps, 1 turnsignal light, and too many to count oil filters...soon to replace the struts/springs.
All just routine maintainace stuff really despite the fact that I beat it hard all through the day. This is such a great car.
Oh...well the front end was replaced too from an accident, but that wasn't excatly "wear and tear".
Dude,
2 PVC's?
3 sets of rubber? Is that including stock set, or 3 times + OEM?
4 sets of brakes? Holy $hit, you must be hard on your ride. What pads have you been using and how do you like/what kind of wear are YOU getting?
I just upgraded my rotors and pads but not cause I had to. My fr rotors were starting to warp a little, had a ton of wear left on my pads, but she wouldn't brake worth a damn.
I'm at 69k and should see 80k with no problem on my 2nd set of crappy RSA's(including OEM.
All mods for me!
Old Sep 23, 2001 | 07:27 AM
  #44
jiaxima96's Avatar
96 GXE auto bought new, 35K miles now.
Radio replaced in the first week because of the peeling off paint.
Tires replaced.
Fuel filter replaced at the 30K major maintenance (not so sure if dealer realy did it but on paper it was done).
Old Sep 23, 2001 | 08:54 AM
  #45
Micah95GLE's Avatar
'95, 115K miles, replaced O2 sensors, starter, thermostat, and oil sending unit. Flawless, otherwise.
Old Sep 23, 2001 | 09:16 AM
  #46
ny96max's Avatar
INDYMAX77how much did the rear door hinges cost?? mine are completly wearing down and almost seized up on me
since 38k i have done:
fuel filter
plugs
pcv valve
synthetic oil
tranny fluid (every other oil change)
brake pads
rear rotors
coil pack
all 3 o2 sensors
Old Sep 23, 2001 | 12:57 PM
  #47
peemoeller55's Avatar
96 GXE almost 61K
bought it 16 mos. ago at about 50K and no regrets.
regular oil changes and soon spark plugs.
Old Sep 23, 2001 | 01:31 PM
  #48
2DMax's Avatar
Man I must be slow....98 with 42,000 on it.
- AC Condensor unit @5 K (thanks to a rock at highway speeds)
- Oil sender/sensor do-hicky thingie & VCV @ 33K
still have original brakes, clutch and tires.
Old Sep 23, 2001 | 01:50 PM
  #49
NYCe MaXiMa's Avatar
What's up with this oil sender unit????!?!??!?! Seems like quite a few of you guys have replaced this thing.... WTF is that? How much does it cost? parts + labor?
I now have nearly 58k, no problems yet in the last 1.5k miles That's pretty damn good... If I last another 500 miles I will already have made more progress with this car then my previous maxima which blew the tranny at 86k miles I did have a Check engine light pointing to the EVAP canister and vent control valve, but after taking it off, playing with it a little bit and putting it back on it dissapeared
Old Sep 23, 2001 | 02:15 PM
  #50
MarkP's Avatar
Original owner 96SE with only 26,800 mi.
Normal routine maintenance items plus recall on EVAP components.
OEM battery replaced at 9,700mi due to dead cell.
Alternator replaced at 25K. (diodes blew for no apparent reason.)
Interesting to see no other alternators replaced yet. Mine must have been a dud.
Old Sep 23, 2001 | 03:59 PM
  #51
BriGuyMax's Avatar
I've heard that leaky oil senders are common on our engines. I didn't even notice it...my mechanic did and he showed it to me. I bet a lot more people on these boards have leaky oil senders and don't even know it. I belive the part is like 30 bucks...but you need a special tool to remove and install it so I had to have mine done at the dealer.
Old Sep 23, 2001 | 04:20 PM
  #52
Monil's Avatar
Are there any symptoms of for a leaky oil sender? Would I notice a loss of oil?
Finkle
Sep 27, 2015 09:53 PM
WeetoddA32
Aug 16, 2015 12:45 PM
MaxStock
Aug 12, 2015 08:33 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
