Flashing Airbag Light
Originally posted by max98boom
I all of a sudden when i started up my car today and drove around, the air bag light keeps flashing?
I havent tried much cause i dont really know where to start, the manual says call nissan but i would rather fix it if i could
thanks
thanks
Air Bag warning light reset instructions.
thanks
thanks
This information came from the '99 Maxima factory service manual.
Perhaps your '98 works the same way. It's easy enough to try.
Open the driver's door. Note the rubber covered button, a button which is
pressed by the door when the door is closed. This is the Driver's Door
Switch (DDS).
Turn the ignition from OFF to ON. Press the DDS at least 5 times within 7
seconds after turning the ignition switch ON. Turn the ignition OFF.
Close the driver's door. Start the engine.
Possible causes for this warning light to go on include...
- a fault with the Air Bag.
- abnormally low voltage in the electrical system due to a weak battery.
- a maladjusted door striker plate such that the door does not close properly,
and the DDS is jiggled on and off constantly as you drive.
If the dashboard warning light remains on after you perform this reset procedure you may have to let the dealer handle the problem.
Flashing Airbag light finally fixed!
I wanted to thank Daniel Martin for the instructions to reset this flashing light. Mine started blinking back in 1999 just after a heavy rain storm and the stupid dealer said that the Airbag computer was blown. They said it would be $880.00 plus installation and testing with a 90 day warranty. I used the "Air Bag warning light reset instructions" last night and the light has stopped blinking.
I'll keep you up to date. By the way, the stupid dealer I went to in is Bevery, Massachusetts and is named Kelly. I,ve been bringing my two maxes to two guys that used to work for them, they are great mechanics (NorthEast Auto Lab) in Beverly, MA.
Daniel,
What does this procedure actually do? Does it set the airbag ECU in diagnosis mode? Does it disable the airbags entirely? I'm tired of my flashing light, but I want to make sure that the airbags will deploy in the event of an accident.
-Sryth...
-Sryth...
Daniel B. Martin hasn't been around for several months now, so your answer is not going to be answered by him anytime soon.
I doubt resetting the airbag ECU disables the airbags. Reset it once and if it doesn't come back, it should be ok.
However, if you're still unsure about it, don't reset it and just take it to the dealer.
Originally posted by sryth
Daniel,
-Sryth...
Daniel,
-Sryth...
fastcarny
10-06-2015 10:42 AM
Maxima30
09-07-2015 06:13 PM
