Speaker Replacement in a '96
Old Sep 14, 2001 | 10:07 PM
dko's Avatar
dko
duck and cover
I have a 96 GXE and I'm trying to swap out the rear speakers (non-bose). I tried following Cheston's directions and decided not to go through all the way. The problem is that the top half of the seat feels like it's still attached even after removing the 4 bolts.
Is this normal or is there something else to it? I figured it's better to wait then to bollocks the seat. Should I just yank it harder, or what?
Also, I should mention that my Max has the trunk access latch behind the rear armrest (if it makes a difference).
Old Sep 15, 2001 | 04:52 AM
MaineMax's Avatar
OK - You need to remove the back seat and shelf to get to OK,
To remove your rear speakers.
1.) Remove the rear seat bottom cushion. ( Pull on the 2 plastic rings on each edge. )
2.) Remove the 2 bolts on the outside edges of the seat back.
3.) Fold down the arm rest and door behind the arm rest. Lift the carpet and remove the 2 bolts. Push up on the seat back to remove.
4.) Remove the 3rd brake light assembly.
5.) Pull back the door edge molding.
6.)Pry out on the rear pillar trim panels to release the clips. Let them hang by the rear seat belts.
7.) Pry up the rear deck panel and slide it toward the front to remove.
8.) Now you can get to your speakers
Good luck.
Old Sep 15, 2001 | 06:25 AM
gtr_rider's Avatar
192.168.1.1
I'm going to reput my how 2 back up, so that you can see a graphical removal of the seat...Also I added many how to's for 3rd, 4th, and 5th generation maximas...Come See!!!
Old Sep 15, 2001 | 06:27 AM
NickStam's Avatar
read this
http://www.performanceix.com/how-to/...er_removal.asp
Old Sep 15, 2001 | 06:29 AM
gtr_rider's Avatar
192.168.1.1
Originally posted by NickStam
read this
yea there it is Thanks Nick
Old Sep 15, 2001 | 07:31 AM
dko's Avatar
dko
duck and cover
Thanks!
Thanks much! I'll give it a try today and let you know how it goes.
PH98I30
29
Feb 10, 2025 12:03 PM
cruce91
Sep 20, 2015 10:23 AM
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
