hesitation up ahill
hesitation up ahill
I have a 1998 max and i've been having some problems with it lately. I recently replaced the spark plugs and the fuel filter and thats when i think the problem started. I was going up a hill and kept my foot steady on the gas and noticed a very slight hesitaion in the car. It only happens when I keep my foot steady on the gas going up a hill. It feels like the car doesn't have enough power to get up the hill, so I give more gas and the hesitation stops. Any thoughts???
Re: hesitation up ahill
ummmmmmm...... auto tranny shifting?
I know all auto trannies don't shift as smoothly going uphill..
Now that you mention it, i have some hesitation with my max as well, but it's on regular straight roads after I begin to accelerate, car moves then jerks a little then begins to pick up...and it's not a tranny shift for sure.
same thing happens to me...the jerk you feel also happens in my car. from what i understand, its merely the design of the tranny...in my opinion, its not the best tranny for this car. from what i read previously, the tranny behaves like this for fuel economy reasons...same reason why you dont get a good start when coasting thru a stop sign (car still remains in 2nd gear when coasting thru at around 5mph).
I'm no genius but if the problem started after he changed his fuel filter and plugs I dow't the tranny whould be the Culprit.
How does your car idle? Any signs of it wanting to stall or anyting? My 5spd I30 use to have hesitation problems and when I hit the gas harder the hesitation whould go away. The problem was a damaged MAFS. You may have damaged your MAFS when you changed your fuel filter. This is just a possibility, more info whould help with hte diagnostics.
![bonk](https://maxima.org/forums/images/smilies/bonk.gif)
MAF is a possibility no doubt. I've heard of even worse things happening when the MAF is damaged.
Originally posted by medicsonic
Ethan, are going to start selling MAF sensors? You seem to diagnose every engine problem back to them.
![Wink](https://maxima.org/forums/images/smilies/wink.gif)
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Stillen_I30, my check engine light did not come on when my MAFS broke, it seems to rarely set off a MIL code.
Where is the mafs and how much does it cost to fix. Also what does it do???
For more information about the function of the MAFS and a test procedure, please refer to the Chilton repair manual (page 4-16) or the Haynes repair manual (page 6-9).
how can i test to see if it is bad, does a bad mafs cause a hesitation up a hill??
JoshG
51
09-21-2015 10:41 PM
jchronis2552
09-21-2015 05:52 AM
trungg86
09-04-2015 04:58 AM
conansriver
09-03-2015 06:38 AM
