Spring noise update - found the source!!!!
Old Oct 11, 2001 | 02:05 PM
  #41
Stealth Max's Avatar
Originally posted by Lime
not too hard, but you may have to use a spring compressor.... Jack up the car, unbolt the top/bottom bolts. The top I think are 2 12 mm in the rear, and the bottom is some huuuuggggeee thing. My chilton's isn't here. For the front, get the metric equivalent of 7/8 for the top bolts if you have a 97+ with the rounded nut things, otherwise it's a different bolt size...well...anyway, compress the springs and release the tension, then take the strut apart (make sure number the parts, and also label the orientation of top/bottom if you don't have a complete strut assembly to look at!!!). Wrap the whatever-you-use around the springs' tops and bottoms. Put stuff back together. Bolt in struts. Put car on ground. Torque struts. Test drive.
Bet you thought a gurl wouldn't post this.
WOW Lime you are getting more and more impressive everyday! I don't care what the others have said about you. They are all nimcompoop!
Old Oct 11, 2001 | 02:17 PM
  #42
Lime's Avatar
heh...well that was pretty generalized.
hah...I don't really care about what certain people who have been kicked off this board before say, actually...so ah...yeah...I am just here to enjoy my car and stuff.
Old Oct 11, 2001 | 02:23 PM
  #43
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
btw, this should become a sticky!!! or something resembling it!
so are you back lime. i love you
Old Oct 11, 2001 | 06:19 PM
  #44
njmaxseltd's Avatar
If you have H&Rs you dont' need a spring compressor to take them apart.
Old Oct 11, 2001 | 07:53 PM
  #45
it's way easier and slightly safer, i used one for my eibachs. made life easier.
Old Oct 15, 2001 | 06:52 AM
  #46
SMX's Avatar
SMX
Ok I did it this weekend … The gray sleeve that was on the bottom of the spring was torn. I saw it was where it was making metal to metal contact. So I place the rubber hose on the spring where it was making contact. Well I still hear it not as bad as before but its still there, but now I am hearing squealing noise from the hose. this is driving my nuts. What next?"
Old Oct 15, 2001 | 08:30 AM
  #47
Lime's Avatar
a squealing??? are you shure it's from the hose? I wrapped the first 3.5 coils, then put a bit of the hose at the very end of the springs...no noises.
Old Oct 15, 2001 | 08:53 AM
  #48
njmaxseltd's Avatar
Ms. Lime girl, are you coming to the Woodbury commons meet? I want to see exctly how you wrapped your coils. Like I said earlier the vinyl I used makes some noise when it's cold outside. Other then that, I'm pretty quiet now too. But I'm not going to stop screwing around until I get silence all the time!!!!
Old Oct 15, 2001 | 09:15 AM
  #49
SMX's Avatar
SMX
Its sound like when you have a bad strut, And the noise is not 100% gone.
Old Oct 16, 2001 | 05:33 AM
  #50
Lime's Avatar
uhmmmmm, with the way things are going, no...probably not. If I do, it won't be in the "caravan." Depends on if I have to work and stuff too.
Old Oct 16, 2001 | 06:08 AM
  #51
Sonic's Avatar
What caravan?
Old Oct 16, 2001 | 06:14 AM
  #52
njmaxseltd's Avatar
Originally posted by medicsonic
What caravan?
This one.
http://forums.maxima.org/showthread.php?threadid=70579
Old Oct 16, 2001 | 06:23 AM
  #53
Sonic's Avatar
This one.
She lives by Hartford, CT. She's not going to be a part of that one.
Old Oct 16, 2001 | 06:37 AM
  #54
njmaxseltd's Avatar
Good point.
Old Oct 16, 2001 | 06:43 AM
  #55
Sonic's Avatar
I try.
Old Oct 16, 2001 | 09:16 AM
  #56
Lime's Avatar
there is usually a MA caravan too, which I could pick up, but I wouldn't.
Old Oct 18, 2001 | 06:16 PM
  #57
Lime's Avatar
STICKY!!!
We need to make this a sticky!
Here's a picture of my wire-wrapped H&R's on the rear over the tokicos.
Old Oct 18, 2001 | 09:51 PM
  #58
VQdriver's Avatar
Re: STICKY!!!
am i going insane here? i know i have eibachs, but i was told to have the progressive part of the springs on the bottom! can someone please finalize this with me? the word EIBACH is right side up and the progressive coils are on the bottom. so many people have them "upsidedown" or so i think. oh, i think i'm going to replace some of the rubber parts that isolate the shaft on the rebound. that's the only other thing i can think of. i've spent too much $ already, but it must be done and it will!
Old Oct 19, 2001 | 06:44 AM
  #59
njmaxseltd's Avatar
[B]STICKY PLEASE!![/B]
Nice pic Lime girl! Thanks for your input to this important thread.
Old Oct 19, 2001 | 07:45 AM
  #60
clee130's Avatar
You want a sticky? I'll give you a sticky! However, there's a lot of "other stuff" in this thread and since I'm unlowered, I'm completely lost. So, someone start a new thread with JUST THE IMPORTANT INFORMATION and I'll make it a sticky.
Old Oct 19, 2001 | 08:53 AM
  #61
Lime's Avatar
Re: Re: STICKY!!!
Uhm...I put them in the way I took them out. H&R is right side up, and the car is happy as far as I know. I son't know about eibachs, but the coils on the H&R's are close at the top and bottom, and not in the middle...because the car is on the ground with the tires on, I can't get the bottom...next time I have him up in the air I will take a better piccy.
cruce91
Sep 20, 2015 10:23 AM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
Hdnseek
Sep 9, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
