whine from passenger side of motor
Old Oct 4, 2001 | 02:59 PM
Bags's Avatar
VG Ridah's Biatch Hoe
i hear a whine when driving from the right side of the motor. it happens at multiple speeds, 20,30,50 but it is at about 2300-2500 rpms and only when i am slightly on the throttle. it sounds like belt whine, but the belts seem tight. BUT i could be wrong. i do not hear it at idle either. have not checked it at a stop while pushing the throttle, i will be checking it when i go home tonight. i was wondering if anyone has had this or heard this???
Old Oct 4, 2001 | 03:21 PM
Daniel B. Martin's Avatar
Dry bearing
Belt whine could come from a dry bearing in the belt idler/tensioner, air conditioning compressor clutch, or alternator. You may be able to locate the source with the rubber hose listening technique.
Old Oct 4, 2001 | 03:25 PM
Rubber tube listening aid
A four-foot length of small diameter rubber vacuum hose will help you identify the source of an unusual sound. You can buy the hose in any auto parts store. They typically sell it in bulk for about US$0.80 per foot. Start the engine and let it idle. Put one end of the hose in your ear and the other end near any suspected source of noise. The engine compartment presents a cacophony of sound. The benefit of the hose is that it isolates the sound from one specific area. Work safely! Avoid contact with moving parts!
You may find it interesting to explore the sounds of your engine with this inexpensive tool. Each moving part has its own characteristic sound. For example, listen to the muted clicking of the fuel injectors. They should all sound alike. If you find one with a different sound (or no sound at all) you have found a problem.
The dealer's service department is equipped with high-tech diagnostic instruments. These are wonderful devices but they are expensive and the dealer has to recover his cost by charging you for diagnostic time. Sometimes the home mechanic can do legitimate diagnostic work with nothing more than a rubber tube.
Old Oct 4, 2001 | 03:26 PM
Bags's Avatar
rubber hose??
is that where you put one side to your ear and the other roams around the engine until the noise is the loudest? i never heard of this but after 5 minutes of sitting here i kinda figured it out. ok, sounds like a good idea thank you
boomerbrian
Oct 31, 2018 10:25 AM
Maxima30
Sep 7, 2015 06:13 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
maximusrising
Sep 2, 2015 09:55 AM
