TPS Problem- Please Help(DBM)
Old Oct 9, 2001 | 06:47 PM
Miguel97GLE's Avatar
My Check engine light came on over the weekend and I just had a chance to pull the codes. I got a 0403 code and a 1206 code. Considering they both point to the TPS I was wondering which component is more likely to be the cause. The Throttle Position Sensor or Throttle Position Switch. Is their a simple way to determine the offending part? Which is the more expensive and is this something I could fix myself(given a moderate amount of mechanical ability)? Any help would be appreaciated.
Miguel
Old Oct 9, 2001 | 08:13 PM
Bump
Bump
Old Oct 9, 2001 | 11:55 PM
brianw's Avatar
TPS is around $150 from Courtesy Nissan. Not a very difficult fix, but you should at least be an experienced wanna-be monkey before attempting such a repair without assistance.
TPS Sensor and TPS switch are the same part, so it's just a single $150 part to replace.
Roymg
Sep 3, 2018 05:10 AM
schmellyfart
Sep 25, 2015 04:47 PM
sake1bs
Sep 19, 2015 09:32 PM
Max96LSU
Aug 28, 2001 08:08 PM
Nealoc187
Jul 18, 2001 01:28 PM
