D.B. Martin... need ur help... seems u know ur shiz
i did that self diognostic thing to my 96 max and i got two codes.... one being...0903 witch means EVAP canister control valve... that has to do with the a/c i suppose... but thats not what concerns me..... the other code was 0304... witch said it was the Knock sensor.... what is a knock sensor... and what are the symtoms of somthing bad about to happen.... do u know the part #... or where i can get it..... any info will be greatly appreciated..
thanks.. im kinda new to the whole maxima thing.. i was a VW owner and lemme tell u theres nothing like a max... thanks again
-RiCk
-RiCk
Re: D.B. Martin... need ur help... seems u know ur shiz
Do a search for knock sensor and check the stickies above for some more informative information
-RiCk
-RiCk
i'm not daniel b, but i can share my recent experience with you ... i too have the knock sensor code in my car & some other helpful members here said it's probably an error on nissan's part. chances are your sensor is fine. good luck & i'm sure mr. martin can help you much more than i can.
maury
maury
well umm... thanks
thanks maury
i was reading the help the others gave u.. caue i did a search like i should have done in the first place... instead of bringing up the same subjust .... well new bee's always screw up so... here we go... bare with me... thanks alot by the way
-RiCk
-RiCk
same here
Originally posted by Maury
hey no problem ... i don't mind helping anyone here ... i've been very fortunate - i find this forum and the members very helpful. i'm just glad if i can help someone in return.
maury
maury
Now I get a code for the Valve control after I installed the cone filter?!!?!?! (ANY HELP ON THIS?)
and my AirBag began flashing again, reset won't make it go away anymore. Gets annoying, and I don't want to spend so much money analyzing it and fixing it at the dealer. (ANYONE???)
Oh well...
PS
If anyone had some issues with the above, please gimmi some feedback.
I did the search on the Valve thing and the airbag, but they don't tell me much.
HEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEELP
Re: same here
There is a campaign out for certain Max's..I have a 96 and there is some sort of emission campaign..it will replace a bunch of o2 sensors and some of the evap sensors, perhaps you car has not had this done.
You may want to check it out with you local dealer.
Right now, I have a check engine light on for my two front o2 sensors and the knock sensor, but have read that they go hand in hand, so I am not real concerned with the knock sensor..
Hope this helps in anyway
Originally posted by Riot^
It seems I had or may still have that Knock thing light up too. Never affected the car though, as far as I can tell.
Oh well...
PS
Oh well...
PS
VQMaxSE
Mar 6, 2001 12:19 PM
