Steering problem
Old Nov 1, 2007 | 03:36 PM
'96 B-rad's Avatar
Steering problem
Okay, so I got in my car this morning backed up switched to reverse then back in drive and as I was turing the wheel sharply to the left the steering wheel felt like it was bumpy and it was a little hard to turn. When I left work it did the same thing only worse felt. I went to turn the steering wheel and it felt like it was grinding.. I cant really explain it to well but any ideas?
Old Nov 1, 2007 | 06:22 PM
ROCKART's Avatar
wants an I35
power steering fluid?
Old Nov 1, 2007 | 10:23 PM
max ride 41's Avatar
that sounds to me like your rack is going bad. when its cold its hard to turn. so, do these 2 things: 1. flush your p/s fluid and have them put some conditioner in with the new fluid and 2. check your level as rockart said and look for leaks in and around the power steering resevoir. if its low, it will make noise and turn hard. be careful, colder air makes it worse.
Old Nov 2, 2007 | 03:19 PM
lexoid's Avatar
check you "power steering" belt, it may be slipping.
lowpost99
Oct 26, 2025 06:53 PM
Mar 12, 2020 12:06 AM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
slowlifer
Sep 8, 2015 05:53 AM
