Can I get pictures of Engine bay grounding?
Old Nov 16, 2007 | 10:00 PM
  #41
crazy97's Avatar
Originally Posted by hermtm2
Hi.
I need some pictures of the engine bay grounding. I will rewire the ground wires to get rid of hard to starting problem when the engine is hot.
I met a kind guy who told me about the ground wire. He recommand here are a lot of pictures and information related to engine grounding to me.
Honestly I'm not sponsor member yet, so I couldn't use the search function.
Can you help me?
Thanks.
I think you may have a bad sensor somewhere. I don't think it is grounds.
Old Nov 16, 2007 | 10:23 PM
  #42
crazy97's Avatar
Engine won't start hot:
You've driven your car for a while and you stop somewhere for a short time. When you try to start the car again, it won't start.
Possible causes:
Ignition module or main EFI relay may be overheating: Replace affected parts.
Vapor lock: Open hood and allow the engine to cool for about 30 minutes. Insure heat shields and/or supplemental cooling fan is working properly.
There is a fuel injection problem: EFI system meeds to be scanned to find problem. Possibly a bad ECM or Coolant Temp Sensor.
Engine turns over slowly when warm:
When you try to start the car when it's warm it cranks very slowly. Sometimes it will start, but most often it won't.
Possible causes:
Engine oil may be to thin or contaminated with gasoline: Change the oil and filter. Use the proper grade of oil.
Dirty or loose battery cables: Clean and tighten cables as required.
Battery is weak or dead: Test battery and charging system. Replace battery.
Battery cables are bad: Replace the battery cables as required.
Starter is overheating: Replace the motor.
http://autorepair.about.com/cs/troub...g/a/bl304a.htm
Old Nov 18, 2007 | 07:38 PM
  #43
hermtm2's Avatar
What is the ECM? Can I replace by myself?
Old Nov 18, 2007 | 09:21 PM
  #44
96blkonblkse's Avatar
If you search you will see a post by certain member (Matt93SE). He brought up a good point about the active tuning grounding kit.
Ill try find it, perhaps it will shed some light in this thread on why the active tuning grounding kit is not very good.
Old Nov 18, 2007 | 09:43 PM
  #45
hermtm2's Avatar
I'm not a sponser member, so I can't use the search.
Sorry...
Old Nov 19, 2007 | 06:47 AM
  #46
99grnmaxgxe's Avatar
I installed the four new grounds today. But they don't help getting rid of a hard starting problem. Help me... Nobody know about the problem even dealership.
Told you that wasn't the problem.
Old Nov 19, 2007 | 06:49 AM
  #47
mowgli29's Avatar
Horizontally opposed.
google search
"site:forums.maxima.org whateveryouwanttosearchfor"
also, the tranny could be poorly grounded to the engine, or the starter may be poorly grounded to the transmission.
I know they seem far-fetched, but I've seen a car so bad that 9/10 times it WOULDN'T start..ground wires were added...still nothing...The tranny was taken off, mating surfaces cleaned, and the car started perfectly afterwards.
keep in mind, that was when installing a used tranny; the mating surface had a chance to get dirty. On your car, probably not the problem, just pointing out that ground wires may not fix things like that.
My dad, a nissan mechanic, says they've had a lot of problems like this over the years, 4th gens especially. 98% of the time it was ground issues, and rarely the issue never could be found.
good luck!
Old Nov 19, 2007 | 09:49 AM
  #48
Peebs187's Avatar
^ Google site search, awesome. Some people don't even know about CTRL F.
Old Nov 19, 2007 | 09:53 AM
  #49
mowgli29's Avatar
I love CTRL+F so much I want to marry it.
Old Nov 20, 2007 | 07:27 AM
  #50
hermtm2's Avatar
Do you think how many groud wires are enough to get rid of the problom?
I made 5 grouds now.
Old Nov 20, 2007 | 07:52 AM
  #51
mowgli29's Avatar
Like I said, you might add 32 gound wires and still have the problem. Try taking the starter off the tranny and sandind down the mating surfaces.
Old Nov 20, 2007 | 08:06 AM
  #52
hermtm2's Avatar
I will do it too.
Hondarydr
Dec 30, 2024 06:15 PM
maxinout93
Oct 27, 2015 01:29 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
Nintensity
Aug 13, 2015 05:41 PM
