Help with codes..
Old Nov 24, 2007 | 10:07 PM
Tmcgradyfann1's Avatar
close but no cigar
Help with codes..
I got codes
0104-VSS
0304-Knock sensor
I have been having problems with my speedometer for a while where it would cut on after i have been driving for a while and then randomly it would just stop working and go back to 0. So do you think that is something to do with the wiring and if so how do you get to that wiring?
and the knock sensor is it a DIY job? or should you go to a mechanic. Some people i have read about on this issue drive around with their Knock sensor bad for months and it doesnt hurt anything? please explain someone
Old Nov 24, 2007 | 10:26 PM
EnervinE's Avatar
i has college
Driving with a bad knock sensor will not hurt anything as long as you don't use crap gas. You can replace it yourself. Go buy a swiveling 12mm socket and a 14" extension and set aside an hour.
Old Nov 24, 2007 | 10:30 PM
close but no cigar
well now a days since bill gates is the only one that can afford premium gas, i go with the crap gas.. so darn but yea thanks man ill have to find out where its located. and i was kidding about that little funny, because majority of you guys use premium i just never did i am sorry.
Old Nov 24, 2007 | 10:59 PM
99BlackMaxMS's Avatar
The VSS code is for the Vehicle Speed Sensor and by changing that, your speedo will be fixed. Change the Knock Sensor as well, and use 91+ if you want to keep the code away. It may seem more expensive to pay $4-5 everytime you fill up, but it beats dealing with retarded timing from a KS code IMO.
Old Nov 24, 2007 | 11:07 PM
vqmaxman's Avatar
It's obvious that Nissan put the O2 sensors so it can monitor the flow of the air and fuel mixture. If it has a bad grade of gas than it's going to retard and when it retards there are so many chances of the pistons mis firing and hitting the valves than your engine will be damaged. I am assuming this the way it works.
Old Nov 25, 2007 | 12:39 AM
pmohr's Avatar
No more Maximas...
Err...what?
O2 sensors are for keeping the engine running ~stoich in closed loop, not for detecting knock.
The knock sensor retards the timing when it detects knock, not just when you have bad gas.
Pistons don't misfire
Without the timing chain breaking or skipping teeth, your pistons will never contact anything they're not supposed to, including the valves.
Old Nov 25, 2007 | 12:56 AM
close but no cigar
Where exactly is the VSS located, i know on the transaxle, but im pretty confused
Old Nov 25, 2007 | 06:31 AM
Kevlo911's Avatar
Kevlo for President
Buy a Haynes manual, or a FSM. Have you checked the Autozone repair manual in the stickies?
Old Nov 25, 2007 | 07:07 AM
Afterlife's Avatar
I don't know how many of you know this but just about any code that comes on can trip the "Knock Sensor" code with it.
I see it daily and the last 5 years have replaced 2 "Knock Sensors" for being faulty.
That's with an average of 600-900 Nissans coming through my shop on a monthly basis.
Old Nov 25, 2007 | 07:22 AM
andrei3333's Avatar
I heard that before
but I think that most people who dont know about these (and all ) cars in general use 87 and thats what trips the KS code, since its a ghost code they dont know about it until their o2 goes or whatever else causes the code and when they go to the mech they realize their KS code is also tripped.
Since you see so many nissans, is there a pattern to what codes cause the KS to come up with it ?
Do you replace the KS if it is not faulty and the code just came up due to something else? (lol)
Old Nov 25, 2007 | 10:04 AM
close but no cigar
yea but see i already knew my VSS was going bad becuase my speedo hasnt been working right since i bought the car about a year ago. so i guess the KS code triggered the SES light. becuase i bet if i did a diagnostic i would've gotten the VSS code since about a year ago
Old Nov 25, 2007 | 10:24 AM
close but no cigar
I checked the Autozone repair manual and couldn't find any information
Old Nov 25, 2007 | 11:51 AM
close but no cigar
http://cgi.ebay.com/ebaymotors/Nissa...spagenameZWDVW
Would that work?
Old Nov 28, 2007 | 03:19 PM
vilmaxima's Avatar
i did my KS last summer, I noticed more pull right after switching it(which is not too easy to do) And lately with high price in gas ive been using the cheap stuff for almost a year, and the code has not come back.
Old Nov 28, 2007 | 05:16 PM
NmexMAX's Avatar
dot dot dot ...
Cheap fuel does not trigger KS code.
Old Nov 29, 2007 | 01:38 PM
DBear's Avatar
Everybody else wants to talk about the KS, so I'll talk about the speedo.
I had the same problem. I replaced the VSS on the tranny (which didn't help), and pulled the instrument cluster and tightened the screws on the back a couple of times. That worked for a little while, but the problem came back. I finally had to replace the cluster. I got a used cluster from someone on the forum (forget who), and it's been fine since. Fortunately the mileage was close enough to mine that I didn't bother fiddling with adjusting it.
There are a number of threads that essentially say the same thing--test/replace the VSS, tighten screws, and if that doesn't work you need a new speedo head (or cluster).
Old Nov 29, 2007 | 01:49 PM
NmexMAX's Avatar
dot dot dot ...
Cliffs:
Process of elimination re: VSS/Speedometer issues
Steps should be performed in this order, if step does not alleviate the problem, proceed to next sequential step.
1.) Replace VSS
2.) Tighten screws on gauge cluster (re: speedometer), carefully.
3.) Get a new gauge cluster.
myshelly2010
21
Sep 22, 2013 11:15 PM
Dracc
Sep 9, 2010 08:49 AM
BLACKKILA.GTR
Jun 11, 2009 12:27 AM
SPER
May 12, 2009 11:53 PM
