Whose got the highest mileage?? Any issues?
Old Mar 27, 2012 | 05:15 PM
  #481
99SE-L5SPEED's Avatar
i have 182000on my 99 se 5 speed nothing big knock o2 sensor my dads has 260000 runs fine
Old Mar 31, 2012 | 05:42 PM
  #482
gregkal123's Avatar
97 max
i bought my maxima at 161k miles now im at 164k miles getting oil change done tomorrow, idk if there was any problems with the car before i bought it but all i know is that i bought a starter for it... and thats it, also just bought tints looks nice about to put a couple pictures up, i also want to tune ^.^
Old Dec 24, 2012 | 11:40 PM
  #483
Ed Bwoy's Avatar
My high mileage testimony:
I bought my 97 SE MT with 160k miles 2 summers ago. Wouldn't win a beauty contest by a long shot, but it was really strong. I bought it from the original owner and the paperwork showed that nothing aside from brakes and regular oil changes had been done. Its now sitting at 210k miles and even despite being used as a tutor car for 3 teens, original engine and tranny are still strong. I still win my fair share of stoplight championships.
Someone backed into it the other day and with my preliminary guesstimation, I see it being totaled. Will wait and see, but might be time to let go of old faithful
As an aside, while shopping around for cars, I talked to someone who had just sold his dad's 97 i30 with 587,000 miles. The drivetrain was original and it was on its 2nd set or rear tires(the original nissan ones having been changed at 2xx,xxx miles) The buyer turned the key, busted a U-turn and blew along the road at say 80mph, came back and paid 800 bucks for it.
Old Dec 25, 2012 | 03:44 PM
  #484
TravisCadello's Avatar
seen a 97 in junkyard with 412xxx miles.
Old Dec 25, 2012 | 07:21 PM
  #485
cjandura's Avatar
Whats this "tints" you speak of and how many HP's it add?
Old Dec 26, 2012 | 07:07 AM
  #486
plugeye's Avatar
99max, 249k miles.
plenty of issues
Old Dec 26, 2012 | 07:38 AM
  #487
Ed Bwoy's Avatar
Maybe a list of my issues might be helpful as well.
regular oil, brakes & tires
CEL for O2 and knock sensors
Cylinder 3 is constantly randomly misfiring, I keep coils in stock
New starter, still has a few almost-starts all yr round
New exhaust from the cat-back
New shocks and struts at 180,000
New hose to clutch slave cylinder at 190,000
Replaced pass e-brake cable that had been pinched and rusted thru
can never seem to get the front well aligned
Fog lights cracking or somehow accumulating water - lost count
Old Dec 26, 2012 | 09:32 AM
  #488
RedSnap's Avatar
96 with 150,000k Control Arms , balljoints, bushings , KS , central silencer , muffler , 4 struts all needed boots , battery , starter , alternator (x2) , right cv axle , rack and pinion boot luckily wasting leaking.
Problems now : evap cansiter , purge valve , 02 sensor.
I noticed once I put 245/45/17's on the car I destroy most of my suspension and it needed replacement shortly after , now it just needs some camper bolts.
Old Dec 26, 2012 | 09:45 AM
  #489
Maximaguy's Avatar
Just picked up a 98 SE with 297K on it. Original engine and trans. Only thing really done to it over past 3 years was brakes, starter, coilpack, and catback and thats about it. Clean good running car though. I think its held up good with its mileage. Only thing it really needs is valve cover gaskets.
Old Dec 26, 2012 | 11:32 PM
  #490
FreshRichie's Avatar
AMAZING condition for so much mileage!!
Old Mar 14, 2013 | 08:23 PM
  #491
JayBird777's Avatar
389,000!
95 Max.
Original engine and tranny
Old Mar 15, 2013 | 02:33 AM
  #492
kenc15's Avatar
225k original motor and tranny and runs strong, the lady i got it from took real good care of it
Old Mar 15, 2013 | 02:38 AM
  #493
skatin_foo15's Avatar
220k nothing wrong until hitting a cow now my issues with the coil packs. Other than that she's in good shape.
Old Mar 15, 2013 | 09:07 AM
  #494
bobflood's Avatar
Just passed 238K. Third or fourth owner; we bought at 133K for daughter. Totally stock. Over the years have replaced axles, radiator, clutch, struts, rear calipers over and above regular maintenance items. About to do driver's side control arm/ball joint and axle (2nd time for DS axle - got NAPA instead of Advance this time). Still runs like a scalded dog when I test drive it. Excellent vehicle.
Old Mar 15, 2013 | 11:58 PM
  #495
Primii's Avatar
97 MAXIMA SE 5 speed 230k
New Disk brakes and pads
New radiator
New battery
New Air condernser
New Clutch and throw out bearing
New MAF
New knock sensor
New harmonic balancer
New belts
New Ngk laser iridium spark plugs
New gaskets for front and back valve cover, intake manifold, camshaft position sensor
Got tranny wit 116k on 218k
New driver side axle
New alternator at 224k
Cleaned*the TB, IACV, MAF and EGR tube at 225k
Biggest hit was with that LSD tranny. I had this issues all during the 3 yrs that i've owned it!! But awsome, fun, strong and reliable to drive!! (and most of this problems i tried to fix'em my self, thanks to the forum!!)
Old Mar 19, 2013 | 07:15 PM
  #496
agentrice's Avatar
just got a 97 max 5spd with 106k on it. needs new rack n pinion and power steering pump
other than that runs like a boss!
Old Mar 19, 2013 | 08:47 PM
  #497
Zulu Nation's Avatar
95 SE 179,000....looks like my car is middle age.
Radiator
Slave Cylinder
E-Brake cable
O2 Sensor
KS
Alternator
Front Axles
Fuel Injector
Plenum Gasket
VC Gasket
Besides that just regular maintenence. Had the car since 130,000
Got a leaky steering rack and a shot rear caliper. Gonna replace the fuel filter. She idles a little high after a cold start and sputters sometimes during a warm start, but she always starts lol
Old Mar 19, 2013 | 09:00 PM
  #498
AllMaxxedOut's Avatar
189,xxx. Only owner since 9/1997. Still runs like a champ.
Similar issue as with most 4th gens (rack & pinion, rad support and x-member).
Once it warms up will take care of exhaust leak, axles (drop) and then 3.5 swap. :-D
Good to see 4th's still running strong.
Old Aug 17, 2013 | 09:25 PM
  #499
hatchexhaust's Avatar
1996 2ed engine orig trans 363000 and counting. I drive it every day at least 100 miles per day minimum. Sometimes up to 125 miles per day. This is by far the most reliably car maybe ever and is bulletproof tough and mine is plenty quick and embarrasses on the regular.)))>
Old Aug 17, 2013 | 09:41 PM
  #500
For example; I smoked a guy in a new 13' altima with ease. And the other day I completely embarrassed some kid in his super charger cobalt, and I was bearly gettin in it and I could here his **** winding out as I pulled away with ease at about 3/4 throttle.
Old Aug 17, 2013 | 10:38 PM
  #501
bprice92's Avatar
197k
-BASICS: tires, synthetic oil + filter, coolant, power steering fluid (ATF), ATF transmission fluid + filter, cone filter, wipers, battery, spark plugs, fuel filter, ac/ps belts
-Muffler/resonator
-coolant temp sensor
-front + rear valve cover gaskets
-transmission pan gasket
-upper/lower oil pan, gaskets
-intake plenum gasket
-IACV gasket
-TB gasket
-knock sensor
-vapor canister
-various hoses
-passanger side window regulator
-alternator (3) first one lasted 180k.. Then I became a bass addict
- Radiator
-hood struts
Old Aug 19, 2013 | 09:39 AM
  #502
LTXMitch's Avatar
'99 SE 142,xxx
2 airbags
Hood
Bumper
Quarter panel
Both lower control arms
Both valve covers
Both front struts
Coil pack
Cv boot
Having power loss issue
And a pull to the right
(THIS HAS NOTHING TO DO WITH THE ACCIDENT NO FRAME DAMAGE SAVE THE B.S)
Old Aug 19, 2013 | 12:03 PM
  #503
maxman1988's Avatar
Coming close to 190K only big issue I had was tranny, but it was kinda my fault...anywho original engine, second tranny and she runs like new :-)
Old Aug 19, 2013 | 12:38 PM
  #504
papa_max's Avatar
209xxx still going strong, I've got to replace my lower control arms but no motor problems
Old Aug 19, 2013 | 07:21 PM
  #505
Macksima2's Avatar
197215 water pump (timing chain, timing cover gasket both done with water pump) and crankshaft pulley. Run great still
Old Aug 20, 2013 | 12:55 PM
  #506
Drag0n97's Avatar
201xxx need to replace radiator and control arms
Old Aug 20, 2013 | 04:57 PM
  #507
big lounumber12's Avatar
I have 96 SE. Bought it with 52,000 miles...now I have 267,000. Original engine and tranny. I just cleaned the IACV, replaced pcv valve, replaced ERG valve and knock sensor, was getting code. Spark plugs was changed once in the 14 years that I had the ride. Gonna change them next week.
i think the car was built to last forever!! But the japanese didn't know it.
Oh...I replaced the O-ring on the camshaft sensor
Old Aug 25, 2013 | 08:51 AM
  #508
BIG D MAXX's Avatar
At 270, 645 she started knocking. So sad to see her go she's a 99 5 speed with interior swap. Mayb time for the 3.5 swap
Old Aug 26, 2013 | 03:11 PM
  #509
Maxima 97 SE's Avatar
Maxima 97 se automatic original engine and tranny, original sensors and original water pump and timing chain. It has 294,625 miles and just passed smog today. Still runs like brand new. The best way to keep it running good is to keep up with maintenance and use the best oil which I use is castrol edge titanium 5w-30 which fully synthetic and use valvoline dex/merc max life transmission oil and use only 91 octane gas.
Old Sep 28, 2013 | 11:31 PM
  #510
blakedanatural's Avatar
2004 max se and I currently have 192000 miles. I got the car brand new in 2003 in may, as a 2004 model., Engine still strong using quaker state oil since 2006. same original trans had to rplace alternator in June.
Old Sep 29, 2013 | 01:12 AM
  #511
MystiWink's Avatar
313.000 oem
Old Oct 21, 2013 | 08:11 PM
  #512
sqaeng's Avatar
Hi
214, 000 miles.
Still using the original radiator fluid. - wait no, I think we replaced a water pump, I don't remember at my age.
Original power steering belt as I can't figure out how to get it off.
missing tensioner for drive belt
oil leaking on exhaust somewhere.
power steering rack seeping
Bose radio goes full blast and I can't lower the volume
broken windshield
rips in vinyl on armrest and seat
plastic mouldings on dash coming off
small dents
in need of paint correction
Does not like to start without giving it gas
hood lift pistons weak.
Does get good fuel economy (29-31 mpg at 5000 -6000 feet)
Old Oct 21, 2013 | 08:57 PM
  #513
Max139617's Avatar
1999 with 296k on it
Put in a new motor at 260k miles with one that had 93k on it due to a bad valve cover
On my second 5 speed tranny
7th set of spark plugs as of 2 days ago
new alternator
new wheel bearings & hubs
4th starter
3rd clutch
too many sets of brake pads to count
2nd radiator support
New coil packs and o2 sensor
3rd knock sensor
Needs:
Water Pump, Lower Control Arms, Axles are near the end of their life, Hood Lifts, New Battery, Another radiator support -.-
Still love this sh*tbox though
Old Oct 22, 2013 | 02:23 AM
  #514
maxima2fst4u's Avatar
171k on mine still counting 2 trans 2 sets of axles id say atleast 3 sets of front wheel bearings thermostat alternator and the hubs 2 starters...these next things where just because i was not getting that ground between the trans and block so really didnt need them lol both cps cam sensor knock sensor maf but other then that motor wise my oil is still clean as a whistle cause i change mine ON TIME like u should uhhh getting some headers 2.5 exhaust new front and rear bumper covers radiator support frame here soon...unless i go to a 5th gen maxima but i doubt it cause after 5 years its not car anymore its family...
Old Oct 22, 2013 | 10:00 AM
  #515
N3SQV's Avatar
225,000. But, she still runs great. No other noise from the engine other than normal noise. Body is ok. I'm pleased. I've had people ask why I don't buy a new car. That's easy, I love my max. Repair wise:
Clutch master and slave cylinder
Starter
Front axles
Rear shocks
Rebuilt 5sp trans
Two coil packs
MAF meter
Exhaust from cat back
O2 sensors (all four)
Clean EGR tubes
Valve cover gaskets
Left front lower control arm
HMSL assy
And obviously wear and tear items
Still needs:
Radiator Support (have the part, just need the time)
Old Nov 21, 2013 | 03:46 PM
  #516
tmarx88's Avatar
264,000 miles,
Still runs like a banshee, no smoke, no issues at all. Runs like its got another 200k left in her. Just sold it tho, cops repo'd my plates and impounded it, 76 in a 55 mph zone. F that!... so I sold it right from the impound and went out and got a 95 (other was a 96) and the 95 i have now has 166K and runs great. Love these V6's and the automatic/od.
Left is the previous 96, right is the new 95
Attached Thumbnails Whose got the highest mileage?? Any issues?-60810_10200984231021624_1841881087_n.jpg   Whose got the highest mileage?? Any issues?-00w0w_3v4xm7u6isg_600x450.jpg
Old Nov 21, 2013 | 04:45 PM
  #517
JoshG's Avatar
1996 white pearl 120k miles blk leather no rips, runs great =) but has airbag light on, i remember my friend who was putting my passenger seat all the way back with power seat and all the way down and my guess was that he stretched the airbag wire and that probably caused my airbag light to turn on, before that it wasn't on.
i only had my car for a year(bought in october 2012) and only fixed/added...
cosmetic***
Darkest Legal tint windows- (April 2013) Looks soooo nice bought most expensive tint at the store with LIFETIME warranty i still have the paper for free tint if it fades in the next couple years!!! especially with the chrome and arctic white pearl (sexy as hell!!)
(December 2012) Replaced head unit with single din aftermarket unit since original bose screen was not showing up,
soon to replace the speakers because i do hear a "Static noise" from the speakers i think, it is kinda annoying and i think they're a blown out or about to. I can still hear good from it but i have to go to volume 20 or somthing to hear.
Most of the time i keep the speakers off (volume at 0) so i dont hear the static and put my ipod on max volume and it works just fine right now.
**repairs* sort of cosmetic no under the hood repairs
Repaired rear driver side window regulator (as i was driving the window just fell down, but didnt lose the window, could not put it back up and had to get a window regulator since that window is the only one that did not work (cost me $220 to get regulator :| ) , after that i got the Window tint .. $460 around there for both window tint and regulator, O_o)
both front tires brand new, 50k mile warranty
one day my driver side mirror fell off while driving cause the sticky part was falling off (good 17 years lasting on that mirror) and replaced it for 10 bucks, not the whole thing just the mirror. gotta keep my car lookin original and good shape.
new car battery, it once died in December and bought terminal for positive side, had it tightned was good for a while, then in September it was really on the edge, died overnight, died the day before that, went to go check for a battery test, and they say" yeah the battery just needs a charge, just on its way to dieing" battery did look kinda oldish. so i bought a really good battery so i didn't have to deal with it again for a couple years.
Old Nov 21, 2013 | 06:12 PM
  #518
Chrono's Avatar
Does anyone know which gas stations in the states sell 91 octane gas? All I see is 87, 89, and 93.
Old Nov 21, 2013 | 07:09 PM
  #519
bprice92's Avatar
I think it depends on what state you live in. I'm in Arizona and 91 is the standard premium. Shell, Fry's, Quik Trip, Quik Mart, Valero, Circle K. Then there's one place that sells like 100 octane racing fuel but it's not your standard place. Think it has to do with state emission policies blah blah blah. But pretty nice for you to have 93!
Old Nov 22, 2013 | 05:12 PM
  #520
LTXMitch's Avatar
North Florida, 87, 89, 93
