To replace or not to replace...
Old Dec 16, 2007 | 11:53 AM
mevjen's Avatar
The self-oil changing max
In a nutshell: I am dropping my engine to put some gaskets in. Took off the y-pipe and cat yesterday and it looks like poo. Oil from my leak and 10 years of wear sure do show. A bolt on the cat attaching it to the rear exhaust broke in half it was so rusted out. Here are my choices, the most economical will be my final decision and I am not sure how to go about them hence my post.
1. Overhaul existing crappy exhaust (clean it up, see if I can rethread bolt hole etc)
2. Buy a new stock y pipe and cat
3. Get a aftermarket y pipe (depending on if I can pass emissions or not)
By the way, the bolt in the cat's flange is still stuck inside, and the other flanges bolts are rounded off so replacement of the cat looks scary...
Thanks for any input.
Old Dec 16, 2007 | 12:04 PM
mevjen's Avatar
Here is the exhaust as of now:
http://picasaweb.google.com/mevjen/E...63510223038690
Old Dec 16, 2007 | 12:50 PM
matty's Avatar
That doesnt look too too bad..
Is the flex section still in tact ??
-matt
Old Dec 16, 2007 | 12:59 PM
BeZerK2112's Avatar
Personally I would do the upgrade with an aftermarket Y pipe and new cat. Looked at some of your other pictures too. You can really see where the oil has been leaking on it, and into the flex section. If you dont have safety inspections I dont see why it wouldn't pass, expcially with a new cat.
Old Dec 16, 2007 | 01:58 PM
mevjen's Avatar
-matt
It is frayed off of where it should connect to the last pre-cat coming off the y pipe.
Old Dec 16, 2007 | 03:32 PM
dgeesaman's Avatar
Maintenance Monster
I would replace the y-pipe only and re-use the rest.
That exhaust looks like new compared to the stuff we salt-belters have dragging under our cars.
Old Jan 12, 2008 | 09:30 PM
rm4628's Avatar
CLICK CLACK 1
I would get new parts and sell the old ones !
Old Jan 12, 2008 | 09:47 PM
andrei3333's Avatar
BTW awesome pictures my friend,
what is that little green **** lableled EVAP service port ? never seen that before
that TB is diiiirty, take it off, clean and replace gasket
Old Jan 13, 2008 | 06:59 AM
njmaxseltd's Avatar
An impact hammer will push the broken stud out of the cat.
If that doesn't work, dril it out and replace with a nut and bolt.
EZ Fix... really.. All the bolts, both sides of my cat have been drilled out and replaced with a nut and bolt.
Old Jan 13, 2008 | 12:50 PM
aznsap's Avatar
ya you can find used aftermarket y pipes for decent price in the for sale section. i would get that and reuse the rest. you'll be happy you did.
Old Jan 13, 2008 | 01:07 PM
kzoosho's Avatar
budget y and find a nice cat and youll be fine.
Old Jan 13, 2008 | 03:25 PM
heynow's Avatar
Originally Posted by mevjen
lol, that's nothing. My flex section is totally gone, and my cat is rust-fused to the y-pipe.
Old Jan 13, 2008 | 05:15 PM
sparky1562's Avatar
So was mine, until yesterday.
If I was you, I would dump the stock from the Y pipe to the cat, and replace them. If you going to all this trouble, why put the stock system back on?
Old Jan 13, 2008 | 05:16 PM
andrei3333's Avatar
^ questionable emissions, thats the reason i am reluctant to do any exhaust work
Old Jan 13, 2008 | 07:29 PM
mevjen's Avatar
I guess it is a service port for the evap system to check functionality, i rerally don't know.
Anyways, I have my car back up and running, I just drilled the bolt out and put a new bolt with a nut on instead of rethreading it. I will probably drop it again and replace the whole thing when I save some more.
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
