Antenna broke - how do I disconnect or fix it?!
Old Dec 27, 2007 | 03:47 PM
CaptainFill's Avatar
Hello,
My power antenna stopped working early this winter and the noise it makes is driving me mad! Turn on the car and listen to gears grinding for 20 seconds and when I shut the car off it goes for another 20 seconds.
I tried to just pull the power plug from the antenna unit but simply cannot find it. There is a large grey one that i disconnected and it still kept going, then theres a batch of cables to it that don't seem to disconnect.
So simply put how do I kill it?! I don't care if it works, I just want to make it so I don't here loud grinding.
Thanks very much in advance!
Old Dec 27, 2007 | 03:49 PM
matty's Avatar
Theres a plug that goes to the antenna in the trunk. Its the mess of wires. The single one is just for the radio connection.
If you want to fix the problem, order an Antenna Mast. Its about $15-$20 and doesnt take that long to install.
-matt
Old Dec 27, 2007 | 04:30 PM
Cool, thanks Matt - could I get a link to an "antenna mast"? I googled it but found nothing.
Old Jan 4, 2008 | 05:31 PM
solow's Avatar
1 LOW MAX
i need the same thing it sucks
Old Jan 5, 2008 | 08:58 AM
johnt671's Avatar
You can find them on E-Bay. I just bought the whole antenna set up for 34.99. Not sure how good it is but if it works for a few years it would be worth the price.
Old Jan 5, 2008 | 07:31 PM
maxim82's Avatar
heres the link http://cgi.ebay.com/ebaymotors/OEM-N...em280188150905 dont spend 35 bucks to fix that
Old Jan 6, 2008 | 01:26 PM
Coolsaber57's Avatar
It sounds like just your mast is broken, which is fairly easy to replace.
I just replaced my motor, which I probably didn't need to do, but it was cheap anyway.
Be careful, though, to get OEM motors, as some ebay ones require you to splice wires instead of using the harness.
Old Jan 6, 2008 | 04:13 PM
nick_auto96's Avatar
Easy fix: unplug the power sourse for the motor. Mine stopped working last year and I just unplugged the cord which I cannot remember where it was. If you look hard enough, you'll figure it out.
chisam14
Nov 6, 2018 08:56 PM
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
maxima297
Sep 30, 2015 03:32 PM
