Steering problem?
Old Oct 28, 2001 | 01:16 PM
skeelo34's Avatar
Steering problem?
I'm just trying to figure out what could be wrong with my car. I recently had a front wheel alignment (about3 weeks ago) from hitting a curb a while ago. In the past few days there is a rubbing sound coming from my front left side. It only happens when turning, and once the car is warm from turning fast from one way to the other. It seems to make a rubbing sound, cant really explain it, its like the sound you get when you run a half dry squeege across a windshield. It sort of slides but hesitates. I dont know either if its bad or just annoying....any help appreciated. Oh and its not like the wheel rubbing or anything, I checked, maybe its something not gettin lubrication or something?
Old Oct 28, 2001 | 01:41 PM
Bags's Avatar
VG Ridah's Biatch Hoe
dumb question... did you check the power steering fluid level? there are 2 levels... 1 for warm 1 for cold
Old Oct 28, 2001 | 01:55 PM
DhaMax's Avatar
hmmm...the most common problem is the wheel well cover, make sure it is not loose, maybe when u hit the curb it popped out or got loose.
Old Oct 28, 2001 | 02:01 PM
skeelo34's Avatar
I didn't check the fluid because its only on one side that it makes the noise....and its not the side that I hit the curb with that needed aligning...I'll look at the wheel well cover, but what am i looking for specifically?
Old Oct 28, 2001 | 04:26 PM
Eric L.'s Avatar
A clunking/grinding noise when turning the steering wheel can be a sign of worn out strut bearings. Check out
http//www.motorvate.ca
for more info on the strut bearing.
Old Oct 28, 2001 | 04:32 PM
skeelo34's Avatar
Its not really clunking or grinding....i think ill get my tape recorder and just record the sound and post it. thnkx though.....
lowpost99
Oct 26, 2025 06:53 PM
Mar 12, 2020 12:06 AM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
slowlifer
Sep 8, 2015 05:53 AM
