big mess or not
Old Mar 6, 2008 | 02:56 PM
soccerplr19's Avatar
big mess or not
okay i posted up here earlier today, i took it to the shop on monday one mech, told me that its my steering boot thats ripped, and also my ball joints have a lot of play. took it to this other shop and the mech over theres like u need tires, u rims are bad, ur struts are bad. this n that which in my perspective is there just trying to make money, i dk what to do.
also, my antifreeze is leaking from somewhere don't know where, the radiator seems to be new, i pop the hood i see antifreeze on top of the rad. and the support i don't know where its comin from, im in dire need of help,
Old Mar 6, 2008 | 04:00 PM
Tfvesquire's Avatar
Well, for starters, you have to let everyone know what year your car is and how many miles on it. Ever been in a front end accident? IMO, you should be looking to diagnose the loss of coolant first and then worry about smoothing out your steering and suspension, If your engine overheats, then you might be walking anyways.
Once you post some more info on your car I'm sure plenty of members will post suggestions. My only suggestion to you is to find out where the coolant is coming from IMMEDIATELY!! If it's a simple fix like a pin hole in a hose then replace it. But if it's a crack in your radiator, then you will be in for a weekend project.
Post some more info and let's get it fixed asap. Worry about the suspension later.
Old Mar 6, 2008 | 04:44 PM
okay so my car is a 95 maxima se with 145k on the body and 90k on the 99 se motor, i just bought the car like 3and a half weeks ago, the guy said it has a new radiator, but while i drive theres no leaks, but when im parked, i check out the car after a while, theres coolant all over the rad support, and then under the car from the passenger side, car doesn't over heat, radiator is filled with coolant. but today i saw white smoke in the front for a few seconds , then it went away. all the hoses seem fine? im assuming the water pump?
also has an antifreeze smell when i park the car from the front, no smoke in the exhaust
Old Mar 6, 2008 | 05:28 PM
pmohr's Avatar
No more Maximas...
If it's dripping out from the passenger (right) side of the engine bay, looks like off of the oil pan then most likely it's your water pump.
Also, don't bump threads 2 (!) times within a matter of hours. We'll see it when we see it. This is a message board, not real time communication.
I assume you didn't read the link I gave you in your other thread? http://forums.maxima.org/showthread.php?t=547220
To save you the trouble:
Originally Posted by Kevlo911
http://forums.maxima.org/showthread.php?t=95555
READ THAT NOW!
This is getting very annoying. I don't care how important your topic is, make sure the thread title is something better than QUESTIONS, HELP ME, OMG LOOOKZ.
This has already been covered in the stickies, but no one reads them...
So please be kind to everyone and make a useful thread topic.
Old Mar 6, 2008 | 05:30 PM
coachholland's Avatar
It's leaking when you're driving it as well. The wind is simply pushing it to another location so it's not noticable. Finding the leak is simple. Clean and dry the radiator, start the car and use a flashlight to see where the liquid is forming. As mentioned, if it's just a hose, simple enough fix. If it's the radiator itself, much bigger job. The white smoke you saw was evaporating liquid from the leaking coolant.
Old Mar 6, 2008 | 06:29 PM
Kbghdg's Avatar
When i first got my 95 gle. I sprayed "soapy water" on the radiator and found a pin hole in the top plastic part. Otherwise it was invisible.
Old Mar 7, 2008 | 08:04 AM
phenryiv1's Avatar
Mod her. Ate her.
Just in case you missed it before...
Originally Posted by phenryiv1
General 4th gen forum guidelines:
First, remember:
This forum is for posts about 4th Gen cars, not just a forum for any post by people who own 4th gen cars.
People, please be more descriptive in your subject titles. For example, "cone intake," "red/clears," "suspension," "emblems," are not subject titles...they are isolated words. Describe the main problem/question/comment in the subject line ... please! Don't type one or two words and make the rest of the Org try to guess what you're trying to say.
And of course, this extends to the body of your post. Please be as descriptive as possible.
Old Mar 7, 2008 | 08:10 AM
^^^^ you are so cool, you know what you win the trophy my friend, your the winner
Old Mar 7, 2008 | 08:19 AM
phenryiv1's Avatar
Mod her. Ate her.
Thin ice, d!ck...
litch
123
Jan 4, 2024 07:01 PM
D Mason
Jun 21, 2016 04:43 AM
MichMaxFan
Sep 30, 2015 09:18 AM
