Troubleshooting Rear Defroster.
Old May 12, 2008 | 05:38 AM
LoSRx7's Avatar
What's the best way of troubleshooting the rear defroster? Currently the light on the switch isn't turning on. Not sure if it's just the LED.
Could there be another connection in the rear half of the car that might have been disconnected? Maybe a plug to the window heat lines and 2nd antenna? If there's one, where is it's location?
Any info would be appreciated. Thank you.
-LoS
Old May 12, 2008 | 05:50 AM
Maxima_Joe's Avatar
4th Gen Parts King
Does the defrost work? If so then the light is just burnt out which is common.
Old May 12, 2008 | 05:51 AM
Kevlo911's Avatar
Kevlo for President
The bulb usually burns out. Search on how to replace it with a LED
Old May 12, 2008 | 06:51 AM
LoSRx7's Avatar
Not sure if the rear defrost works. Light just doesn't turn on. Is there a plug i can test voltage near the rear window?
Is there a link for the led replacement?
Thanks.
Old May 12, 2008 | 07:18 AM
NissanSE98's Avatar
...blow really hard on the rear window and fog it up...then turn it on...if it goes away, it works
Old May 12, 2008 | 07:37 AM
LoSRx7's Avatar
lol I can see my neighbors going "WTF?"
Could there be any harness between the switch to the rear window that could have been disconnected? I noticed there's a plug right behind the rear seat in the lower part. Anyone know if that plug contains the wire to the rear window?
Thanks.
Old May 12, 2008 | 11:25 AM
vilmaxima's Avatar
there is a little plug that connects to the defroster at the back, ^ which is probably the one u are talking about. The light in my hazard button went, but the hazards still work, most likely its the light.
Old May 13, 2008 | 05:13 AM
LoSRx7's Avatar
Do you know the exact location of the plug? I'm going to look to make sure its plugged in.
matts95max
Apr 23, 2025 10:44 AM
GregL65
Jan 17, 2020 08:01 PM
rnb754
Sep 14, 2015 11:39 PM
ballerchris510
Sep 10, 2015 09:35 PM
