annoying front driver noise
Old May 31, 2008 | 09:43 AM
jedinyte120's Avatar
hey guys,
once again my car is making a wierd creaking sound. kinda sounds like the rubber from the cv boots rubbing. i checked and they look fine with no tears in the boots. when i have the car in gear then accelerate and let go of the gas pedal, it starts to make a err err err sounding like rubber rubbing together. but it goes away when im accelerating. the sound comes and goes when i coast in neautral,but goes away when im applying the brakes. at times the sound is louder than others,but mostly its not that loud but annoying cuz i know its there.
i have replaced both axles, driver outter and inner tie rod, driver hub bearings and lower control arm bushings. i have also pushed back the dust shield on the brakes. car drives fine and there is no vibrations.lowered with Teins/tokico struts.
i did a search and didnt really find anything helpful that i haven't already done. insights and advice please,thanks!
roger
Old May 31, 2008 | 09:48 AM
rex3001's Avatar
my car creaks a little too but in my case im pretty sure its the suspension because it was never replaced.
Old May 31, 2008 | 06:39 PM
vilmaxima's Avatar
strut mounts, or strut bearings? if they go bad they tend to make a noise.
Old May 31, 2008 | 07:42 PM
KRRZ350's Avatar
With everything you mentioned, I didn't notice the brakes. Also, are they wearing even? frozen guide pins?
Old Jun 2, 2008 | 07:24 PM
would they actually make the noise when it sounds like a noise from motion? as in the noise only comes when the wheels are spinning and its a constant errr errr errr sound.
Old Jun 2, 2008 | 07:25 PM
i looked at the pads yesterday, and looks like its wearing evenly. what are the guide pins? what do they look like?
Old Jun 3, 2008 | 02:32 AM
cedric's Avatar
Are there any noises when the car is stationary (engine running, in neutral gear) and when you press the throttle?
Old Jun 3, 2008 | 03:17 PM
no sir, no noise when the car is sitting there and throttle pressed. any other suggestion guys?
Old Jun 4, 2008 | 08:35 AM
95maxdvt
same issue
when first had the car made low speed squeal if anybody can explain it as that its wheel bearings been though that lol.
But the err err err noise as best described above lmao is my new mystery as well doesnt seem to be anything loose as ive been through tie rods wheel bearings axles strut bearings need i go on anyway i almost thought it was coming from the rear??? i do hear it in drivers seat but sounded behind me possibles are if its ever been jacked up on ebrake cable by rear drivers tire kind of kinks it maybe its hangin up a lil??
i notice too when car is cold i back out of my parking spot n stop to go forward i hear brake noise in the rear probably related
boomerbrian
Nov 8, 2015 05:10 PM
kingw323
20
Oct 21, 2015 08:36 AM
official_style
Aug 29, 2015 10:10 AM
kirkhilles
Aug 8, 2015 10:53 AM
