96 I30 a/c compressor stopped???
I have a '96 I30 with 195k and the compressor just stopped working this afternoon. When I turn on the a/c, the compressor doesn't engage. This happened like twice before last year, then I would hit a bump in the road and it would work again within 10 minutes of it cutting out. Hasn't happened for a year.
This time it doesn't seem to be kicking back on. I've read the sticky for the a/c compressor bearing, but in the video it shows the compressor engaging, mine doesn't. I also know that there is a FSB for faulty wiring, but I shook all the wiring harness and still nothing happened.
So I am not sure if it is wiring or a bad compressor.
I checked the fuses and everything is good.
The air was freezing cold in the morning, this after noon nothing.
I checked under the engine and removed the plastic shield, the compressor doesn't move when I hit auto on the climate control. So I don't think it is leaking refrigerant.
Anyone have any similar experiences or advice?
Experience with cost to replace?
The car still runs like it did when I bought it with 46k miles, but it is the middle of a Philly summer and it is ***** @ss hot when I have an hour drive each way. I still get about 26-28 mpg (highway) so I am trying to hold off on buying a different car.
Thanks!,
Ok, so I didn't see the post right below mine about the a/c not working on the '97 SE,....
From that post I think what I need to do is check the thermistor, and then take the harness off the compressor and see if there is a current getting to the compressor. I doubt I lost freon. If I still have all that working then I will take it to a shop.
Also, is there a way to bypass the electrical and hook up the compressor to the battery to see if it comes on?
Thanks!,
Thanks!,
Thanks!,
What was your car's manufacture date? I bought an A/C compressor for my '96 (manu in 6/96) and it was the wrong one. Had to buy another one to get my A/C up and running. If you need a new compressor and your I30 was made before 6/96, PM me and I can give you a hell of a deal.
no, I was going to see if I get any current at the wiring harness that attaches to the compressor, not sure if this would be a valid test?
Its hard to get at though, I have to wait until the engine is cool enough, because its far down in the engine between the radiator and the front of the block.
Can I jump the compressor directly to the battery?
also check that voltage is actually getting to the relay.
It's probably be a better idea to swap the relays with a known good one. If you're worried about the harness, you can probably test the harness with a voltmeter. Making a jumper straight to the battery doesn't give me the warm fuzzies with messing with the compressor.
I took off the relay and tested the relay harness, there is power in the harness. I used a simple light tester and it lit up so...
I went to pep boys and they didn't have the a/c relay, 5 days because they have to order it,...I have to wait for my friend who has a '97 maxima to use my relay in his car.
well if you have a test light i would check to see if you are getting a clutch engagement signal first before you go messing with relays...you could already have power there and the clutch could just be sticking. start with the obvious first is what i always say.
I've had this car since '99 and I have never had to mess with an a/c unit before. Where and how would I test the clutch engagement signal?
I can see there is a single wire that goes to the compressor, I'm guessing this is it? Do I have to strip the wire then tape it back up with electrical tape?
id also see if your friend has a spare thermistor to plug in if for any reason the relay doesnt do the trick. i honestly dont think he will though unless he works on them as much as i do...i have a test thermistor that i use all the time, makes life alot easier..hehe
Actually the relay sockets are clipped into a carrier in the relay box. Each one of them are removable into a single socket making access to wiring underneath easy.
The compressor relay is controlled by the ECU and not the A/C controller directly, e.g. if your TPS angle is large, the ECU will cut out the compressor.
well my a/c relay worked in my friend's '97 maxima.
So now from what I believe yous are trying to get me to understand is that I am down to three options here;
1. one of the three thermistors
2. Low Freon
3. Compressor is shot
I wonder what the shop will tell me this Saturday, I have to get it inspected, so I'll ask him to take a look at it.
![Confused](https://maxima.org/forums/images/smilies/confused.gif)
2. Low Freon
2. Low Freon
2. Low Freon
Well all is good , I needed a shot of Freon and the a/c came right back on. Not sure if there is a leak or how slow or fast it may be, but at least I know nothing is wrong with my compressor or anything else.
Thanks for your help guys.
My mechanic charged me $60
04-16-2020 05:15 AM
maxima297
09-30-2015 03:32 PM
