Car will not start....no spark
Old Aug 1, 2008 | 02:49 PM
khantalha+'s Avatar
i put a new engine on my car(98 gxe), and drove the car back to my place (about 50 miles from my buddys place)... had lil bit of problems so i did a full tune up and everything... then it wont start...
my mechanic has had my car for 3 weeks now, has gone thru every wire/sensor there is in the car... we thought it was a ground problem and even replaced the ecu..the problem is its getting spark real slow and we new we had problems with the crank position sensor(pos), so today he called me and said its got something wrong where the motor and tranny mate...cuz the crank position sensor is getting an erratic reading cuz of that and wont let the ecu to send thespark signal...i dont know whats going on? i told him to wait till monday before he goes tearing **** apart...
any help will be appreciated...
i would hate to part it out... but looks like that will be my only option cuz i am sure my mechanics bill is gonna be half a million dollars...
Old Aug 1, 2008 | 07:47 PM
khantalha+'s Avatar
any body?
Old Aug 1, 2008 | 07:49 PM
khantalha+'s Avatar
if not then there will be a full part out of a 1998 sage mist green gxe....pretty soon in classified...
Old Aug 1, 2008 | 07:50 PM
nismology's Avatar
Ground the starter to the frame directly.
Old Aug 1, 2008 | 08:41 PM
crazy97's Avatar
YES!
Old Aug 2, 2008 | 01:14 AM
khantalha+'s Avatar
ait will do monday cuz its at my mechanics...
Old Aug 3, 2008 | 11:51 AM
Slickismax's Avatar
You should be able to pull the CPS out and look inside the hole with a flash light and a mirror. The ring gear should be right there, and you should be able to see how they are matching up. Also, make sure that you/he didn't put the little metal tab that holds the front O2 sensor wire under the CPS. It will put the CPS too far away, and although it will run, it will stumble real bad and have a very hard time starting.
Lakersallday24
Jun 16, 2019 01:35 AM
PH98I30
19
Jun 13, 2016 02:38 PM
Turbobink
Aug 15, 2015 07:20 AM
1992maximase30
Aug 5, 2015 09:27 PM
maxima297
Aug 3, 2015 12:50 PM
