replacing thermostat
Old Aug 3, 2008 | 01:31 PM
4DRSpeed's Avatar
Project Ruby......
I'm in the middle of replacing my thermostat. I've drained the coolant, removed the bolts and such. I know you can use a sealant gasket and I'm pretty sure that's what is sealing everything up. I bought my thermostat and a gasket from Nissan.
I put my hand on the thermostat and give a good tug and this thing doesn't budge, it's like it's welded or basically super glued on. I did a quick search and it doesn't seem anybody has this issue just straight forward installation.
I've tried wedging a pipe and knocking it with a hammer, some vice grips. How in the hell do I get this thing to break free? Do I need to take steroids? Any tips would be appreciated.
Old Aug 3, 2008 | 02:19 PM
Blackwind's Avatar
did you get all 3 bolts? the last one is very well hidden.
Old Aug 3, 2008 | 02:32 PM
4DRSpeed's Avatar
Project Ruby......
i've checked, double, and then triple checked. All 3 bolts are out.
Old Aug 3, 2008 | 02:39 PM
Blackwind's Avatar
when i did my wifes i had the same problem. that bolt tucked under the timing chain cover got me hung up. thats the only thing i can think of unless you got a bunch of corrosion built up under there.
Old Aug 3, 2008 | 03:08 PM
4DRSpeed's Avatar
Project Ruby......
it was the 3rd bolt. I removed the timing chain cover bolt not even realizing it. Just changed it took 5 minutes. live and learn.
Old Aug 3, 2008 | 03:09 PM
pmohr's Avatar
No more Maximas...
Sometimes they get seized up on there (just like the two front access covers on the timing cover, those are a PITA too)...get a pry bar, no reason to worry about damaging the old thermostat housing.
That is, of course, since you have all 3 bolts out.
How's the Max doing, anyway? I remember seeing that thing a year ago or so on one of my many trips down to Oak Ridge...
Old Aug 3, 2008 | 03:20 PM
4DRSpeed's Avatar
Project Ruby......
needs a water pump. im planning on replacing some things get it running well and the turd will be back out on the road. In a year I plan to have the entire car repainted.
Old Aug 3, 2008 | 06:01 PM
QNO_A32's Avatar
Old Aug 3, 2008 | 06:55 PM
khantalha+'s Avatar
glad u got it out
Old Aug 3, 2008 | 07:47 PM
Hexon's Avatar
Wow! One step closer to having that thing back on the road. I didn't know you planned to repaint either. Your max will look pretty sweet soon (sittin' next to mine, that is.)
Old Aug 3, 2008 | 08:30 PM
nyc96max's Avatar
congrat!!
Old Aug 4, 2008 | 03:28 AM
4DRSpeed's Avatar
Project Ruby......
ha. i hope to have it all done in a year. bought quite a few things, I went a little nuts these past couple of days but I want it running better than new and look better than new eventually. Just bought a c/f hood
Old Aug 4, 2008 | 09:41 AM
Hexon's Avatar
c/f hood will at least make it match your bumper for now . JK. Tell me when you get it up and running and we can hit the dragon!
Old Aug 5, 2008 | 06:53 PM
Blackwind's Avatar
hahaha. knew that was it. i cused at mine and scared it into submission.
Old Aug 19, 2008 | 10:27 AM
mitchz's Avatar
i had the same situation on my 92. it was corroded and wouldnt budge. patience pays.
Old Nov 22, 2008 | 06:13 PM
Maxumis's Avatar
I had the same problem today. I got all three bolts out and could not remove the thermostat. I put everything back together and I must have unjammed the thermostat because it worked fine afterwards.
Old Nov 22, 2008 | 06:45 PM
wirelessdude04's Avatar
yea gotta do mine this week when i get my new rad in...
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
