Proper method to break in clutch
Old Aug 29, 2008 | 11:26 AM
wirelessdude04's Avatar
So i just got a new clutch installed ACT street. First time ever having the clutch replaced in my car. SO whats the best safe way to break in a clutch sorry guys newbie to this
Old Aug 29, 2008 | 11:30 AM
JtzMax's Avatar
Whatchyou say?
Well ... to start, rev to about 3,500k or so and then just let your foot fly off the clutch, hold on, give it gas and SMOKE em! lol
Really, I don't think you need to "break it in" at all. That'd be like breaking in a new light bulb.
Old Aug 29, 2008 | 12:01 PM
elemax's Avatar
I've heard you need to go easy on it and avoid going WOT for about 300 miles.
Old Aug 29, 2008 | 12:19 PM
timmay5835's Avatar
i just did a five speed swap. i just babied the clutch for about 300-500 miles
Old Aug 29, 2008 | 12:48 PM
f550maranello2's Avatar
i dont think there is a break in period.. i did 5 speed swap and i didnt really baby it either and i had to remove the trans and the clutch looked fine after like 2k miles
Old Aug 29, 2008 | 12:49 PM
mtrai760's Avatar
'Trynna' is not a word
Easy street driving. Avoid freeways or extended runs at the same RPM, freeway milage does not count (unless it's stop and go). Avoid WOT runs, and take it easy for 500 miles. Then feel free to romp on it.
Old Aug 29, 2008 | 02:35 PM
Snypa's Avatar
burnout time!!!.....j/k....go easy on it. replaced and all should be good.
Old Aug 29, 2008 | 02:36 PM
R33GXE's Avatar
I've heard the break in period is supposed to be 500 miles...
Old Aug 29, 2008 | 02:38 PM
aznprid972's Avatar
I thought you could do WOT run. You just need to baby the launches and no speed shifts.
Old Aug 30, 2008 | 12:45 PM
pmohr's Avatar
No more Maximas...
Why avoid freeways? I really see no reason to do so, just makes the break in period last that much longer. Also, avoid cruising at a steady RPM? For breaking in a new engine, sure...a clutch?
That's how I've always heard it and done it.
Old Aug 30, 2008 | 01:20 PM
mtrai760's Avatar
If you were to get on the freeway and drive 500 miles straight (assuming you had the fuel to do so) you would not have broken in the clutch anymore than when you started. It's the shifting that breaks in the clutch, the engagement of the clutch disc to the pressure plate and flywheel.
I'd also consider WOT to be aggressive driving, and most clutch manufactures recommend light to moderate acceleration until the clutch is broken in.
Just my $.02
Old Aug 30, 2008 | 01:24 PM
pmohr's Avatar
No more Maximas...
Just my $.02
Ah, I see what you mean. I read it as specifically avoiding that sort of steady RPM cruising, as you would when breaking in a freshly rebuilt/built motor.
Old Aug 30, 2008 | 03:14 PM
dgeesaman's Avatar
Maintenance Monster
Just drive the car for a few hundred miles without any hard use of the clutch. It doesn't matter how hard you drive the car as long as you make clean shifts and don't launch it.
Dave
Old Aug 30, 2008 | 07:14 PM
QNO_A32's Avatar
^^ end thread ///
James92SE
142
Jan 2, 2024 09:23 AM
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
Noela
Sep 26, 2015 08:22 AM
