HELP! my belts are burning
Old Sep 17, 2008 | 09:56 AM
ROCKART's Avatar
wants an I35
yesterday was a normal day. didnt do anyhting to my car except drive it to and from work.
last night was a normal night - did not rain or fog or anything out of the ordinary.
this morning i start my car up and i hear a "whirrring" coming from the engine that seems to get louder in volume the faster i go. i figure theres probably some piece of trash stuck in the wheelwell or something and ignore it for a few miles.
i get to a red light 10 minutes later and notice TINY AMOUNTS OF SMOKE COMING FROM MY ENGINE. WTF
i pull the car over, pop the hood and notice that the belt area is slightly smoking and REEKS of burning rubber. but both belts look like they are sitting snug on the tensioners.
what is this? what could have caused it? and how do i fix it?
has anyone else had this sudden belt smoking issue?
i havent done anything to the car related to the belts since about 8 months ago when i replaced the serpentine belt.
last weekend i changed the oil sender unit and the weekend before that i ripped off the whole manifold to remove the excess RTV causing me to run rich, and install a new polished valve cover.
but i havent had any problems with those things until this morning.....
Old Sep 17, 2008 | 10:24 AM
Total shot in the dark (and not even sure this would apply to our cars), but maybe the clutch on your AC compressor took a dump and is locked up; therefore not allowing the pulley to spin freely. Belt is now getting dragged across the pulley, rather than spinning it?
Are the sides of the belt frayed/damaged? If so, that is a big clue something is misaligned now.
Old Sep 17, 2008 | 10:34 AM
black_maxed95's Avatar
ya check to see if all the pulleys are spinning freely and the belt is aligned first. also check to see how tight the belt is. You could try loosening the tnesioner pulley a bit.
Old Sep 17, 2008 | 01:18 PM
internetautomar's Avatar
mod or sell?
that is my thought as well.
Old Sep 17, 2008 | 01:55 PM
ROCKART's Avatar
wants an I35
the belts all look good and they seem the appropriate tightness.
its hard to get my hand down in there, but everything seems normal.
im also curious how this "all of a sudden" happened. i havent been tinkering with my car since this weekend, and it surely wasnt there sunday/monday/tuesday.
i popped the hood again just now right after i got home and it seemed like smoke was coming from the ALTERNATOR, but it could just be an illusion.
im taking it to my buddy at the dearlship tomorrow so well see.
im so broke right now its pathetic.
Old Sep 17, 2008 | 02:21 PM
mod or sell?
if your alternator was smoking, was the battery light on in your car?
I have heard of bearings seizing on alternators which also burns belts, but usually there is a screeching sound first that doesn't go away for a while.
Old Sep 17, 2008 | 04:27 PM
njmaxseltd's Avatar
Take both belts off and inspect all the accessory pullies and the tensioner pully.
One of them is toast, you simply need to find which one it is.
Old Sep 17, 2008 | 07:29 PM
ROCKART's Avatar
wants an I35
you think one of the pulleys is bad?
from the fact that i cant see any damage to the belt, that was my first thought too.
how much should that run me?
both DIY or shop
Old Sep 17, 2008 | 08:19 PM
Snypa's Avatar
Shud be a DIY based on your car experience now.
Old Sep 17, 2008 | 08:25 PM
MaXiM@KiD's Avatar
MaXXiN
Like wizard said I would check the ac compressor..this happened to my cousin started smoking and screaming ....the compressor had locked up...went around the corner my boy had a spare compressor got a belt cause the one he had one snapped after not being able to spin freely and walaaaaa...back in business!!
Old Sep 17, 2008 | 08:33 PM
Divewjason's Avatar
Man Rockart, you have a low mileage max too. How many miles are on her now? If it's just a tensioner pulley I think you would be able to do that yourself if you had a Haynes Manual with instructions in it. Good luck man, I wish you the best.
Old Sep 17, 2008 | 08:47 PM
maxboy325's Avatar
100% true and has happend to me like twice
Old Sep 17, 2008 | 09:17 PM
ROCKART's Avatar
wants an I35
shes at like 55,000 now
Old Sep 17, 2008 | 11:57 PM
arrocha87's Avatar
or if ur harmonic balancer broke in half itll happen too. the smaller inside pulley will sink inside the bigger outside one and the rubber?? stuff that held the pulley togetherwill burn and melt. thats what happened to me. new harmonic balancer was $199.32 with taxes at NAPA.
Old Sep 18, 2008 | 07:31 AM
MOHFpro90's Avatar
Frank, does/did you AC work when this was occuring?
Old Sep 18, 2008 | 07:39 AM
ROCKART's Avatar
wants an I35
havent checked yet
Old Sep 18, 2008 | 09:42 AM
ROCKART's Avatar
wants an I35
alright the AC works great.
i just got back from the dealership and he took a quick look at it. he said its most likely the alternator bearings wearing out.
is that something that can just be regreased? or am i going to have to replace the alternator entirely?
money is very much a mitigating factor here.
Old Sep 18, 2008 | 09:52 AM
Greeny's Avatar
¯\(°_o)/¯
Just replace the alty, unless you have other means of tranportation until you find/buy/install the bearings..Then Hope that was the problem.
Best thing to do atm is stick an volt/multimeter across the battery connections while the car running to check for proper alty voltage, should be in the neighborhood of 13.8-14.3 or something like that. chances are the entire alternator has been damaged by the overheated bearings, i had one reman alty do thew same thing on me while i was 80 miles away from home, by the time i made it home, she was toast
Old Sep 18, 2008 | 10:03 AM
ROCKART's Avatar
wants an I35
im looking at like ~$200 for a new alt right?
Old Sep 18, 2008 | 12:35 PM
IlyaK's Avatar
The Golden One
Damn man. Your car has some sweet issues.
But hey...look at it this way. Instead of paying for an auto class...you're paying in another way...but learning the same amount.
I'd just get a new alternator...and yeah it'll run you about that much.
Old Sep 18, 2008 | 12:45 PM
ROCKART's Avatar
wants an I35
thinking like that is what keeps me sane.
Old Sep 18, 2008 | 03:42 PM
mod or sell?
depends on where you go.
I can get you a brand new one for about $150 if you want.
Old Sep 18, 2008 | 03:59 PM
MOHFpro90's Avatar
Frank, you plan on doing the install yourself?
Old Sep 18, 2008 | 05:18 PM
The alternator is not fun or easy to replace on these cars....
Old Sep 18, 2008 | 05:50 PM
Greeny's Avatar
¯\(°_o)/¯
3rd gen alty= 10 minute job
Old Sep 18, 2008 | 08:02 PM
Snypa's Avatar
Let tallkid helpz you out.
Old Sep 18, 2008 | 08:09 PM
ROCKART's Avatar
wants an I35
im goin back to my buddy over at maroone nissan tomorrow and hes gonna see if theres anyway to extend the life of the current one.
if, worse comes to worse, i do have to swap in a new one he said he would do it for free.
i might take you up on that $150 alty internetautomar. is that an nsisan OEM alt?
Old Sep 18, 2008 | 08:13 PM
mod or sell?
no, it's an 100% brand new aftermarket unit. it's not a reman/rebuild/repaint either.
Old Sep 19, 2008 | 08:00 PM
ROCKART's Avatar
wants an I35
the verdict is in: its the bearings on the alternator
he said its going to get a lot louder before it actually fails, but he didnt give me a timeframe
how long do i have driving on this? id rather not replace it right now because im broke.
is there any way to prolong its life? anything i should or should not be doing?
Old Sep 20, 2008 | 04:30 AM
j2b4osan's Avatar
Well you probably shouldn't be driving the car for starters. The bad alf berings can cause fires ruin belts and cause voltage damage to electrical parts. If I were you I wouldn't drive the car but if I had no choise (like if all the busses blew up or something) I would go to a junk yard and see if I could find a good one. Spin the alt at the junk yard to make sure there is no unhealthy scraping or squeaking and that the pullie turns and stays level (good berings) and if you find a good one and it's cheap but they won't test it 4 u take it to autozone and have them test it. You could probably get a decent one for about 30-60$.
Old Sep 20, 2008 | 06:32 PM
mod or sell?
you can keep packing the bearing with grease in the short term.
but i can not recommend it highly enough to get it replaced ASAFP!!!!
winter is coming which means increased electrical loads on the alternator.
Old Sep 20, 2008 | 08:20 PM
maximase86's Avatar
I love lamp.
You should definately replace it sooner than later. These are one of those problems that if you let it go for too long, it could cost you more down the road.
S
Old Sep 20, 2008 | 09:13 PM
CMax03's Avatar
How can you pack a sealed bearing? Replace that altenator it's not that hard , just jack it up take off the pass wheel and splashsheild and get busy! 30- 45 min.
Old Sep 20, 2008 | 10:12 PM
ROCKART's Avatar
wants an I35
alright well reading your responses about this potentially causing more damage, immona drop the $300 for a new OEM one and get it swapped out sometime this week.
thanks.
Old Sep 20, 2008 | 10:20 PM
Snypa's Avatar
Unless you wanna re-learn the bus route.
Old Sep 21, 2008 | 03:19 PM
ROCKART's Avatar
wants an I35
not funny.
mclasser
22
Nov 12, 2020 01:58 PM
markevans999
Oct 25, 2015 08:27 AM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
