CHampion SPark Plugs, work great!
Old Nov 9, 2001 | 01:47 PM
99GLEE's Avatar
Well as some of you know i just did a tune up and my car feels great..I used CHampion Platinum spark plugs which were around $2.00 each...I plug them right in and my car runs great...the ngk stock i had in there were almost gone and dead...my car is way quicker in pickup now with the champions..has anyone else used them? I think they work great...=]
Old Nov 9, 2001 | 04:54 PM
Blaximazx's Avatar
Re: CHampion SPark Plugs, work great!
I always that these spark plugs work best with chrysler engines and i have stayed away from using them because Nissan engines works better with NGK's.
Old Dec 19, 2002 | 12:17 PM
Euge82's Avatar
Greetings from Cleveland...Home of the Rock and Roll Hall of Fame !
I just bought Champion Platinums $1.99 each. I have not installed them. The auto parts guy said for a GXE with no mods they will work fine. We will see. I will update this post in a few days.
Old Dec 19, 2002 | 12:46 PM
Sprint's Avatar
a GXE with no mods is the same engine as a SE with no mods
any wooo.. see you guys in 60k miles
Old Dec 19, 2002 | 12:58 PM
njmaxseltd's Avatar
Champion plugs belong in your lawn mower.
Old Dec 19, 2002 | 03:25 PM
ivelweyz
Well, 10-20K miles from now you'll probably wish u put NGK's in...
Old Dec 19, 2002 | 03:51 PM
MDubya
I agree. Fine Machinery Deserves a Fine Part. Get OEM Plugs..you'll have to in 1500 miles with those plugs.
Old Dec 19, 2002 | 03:56 PM
finny's Avatar
thats about the only thing i'd use em in
Old Dec 19, 2002 | 04:36 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
Don't put American plugs in a Japanese engine.
Don't put American plugs in a German engine.
Don't put German plugs in an American engine.
Don't put German plugs in a Japanese engine.
Don't put Japanese plugs in an American engine.
Don't put Japanese plugs in a German engine.
Got it?
Great!
lol...
If you have a Japanese engine, stick with Japanese plugs. If you have an American engine, stick with American plugs. German - german plugs too. The engines are designed for the timing/firing characteristics of the plugs that the specific country make. So if you mix/match engines and plug origins, your engine might not run correctly. So best to stick with Japanese plugs only on Japanese cars.
Old Dec 19, 2002 | 05:13 PM
karguy's Avatar
No they don't, I run a NGK plug in my mower. It came with an NGK plug in it when I bought it new from John Deere!
Old Dec 19, 2002 | 07:13 PM
iwannabmw's Avatar
BMW specs NGK's for both my Dad's 98 528i and my aunts 99 328.
Old Dec 19, 2002 | 07:21 PM
kratz74's Avatar
LMAO
So you are saying that a car company spends hundred of millions of dollars on R&D to develop an engine that works best with a couple dollar plug? I think you got that backwards....
Old Dec 20, 2002 | 07:14 AM
njmaxseltd's Avatar
Your John Deere doesn't have a Briggs and Stratton engine in it.
Old Dec 20, 2002 | 07:23 AM
SteVTEC's Avatar
In that case don't put German plugs in a German engine since it was spec'ed for Japanese plugs
Old Dec 20, 2002 | 07:28 AM
SteVTEC's Avatar
Originally posted by kratz74
LMAO
No.
I'm saying that *in general* Japanese companies specify Japanese plugs, which have different firing characteristics (timing delays, spark ramp, etc) than other plugs. So the engineer doing the ECU coding programs the ignition timing to work with the specified plug. About 5 minutes divided by his hourly rate.
If you use something else (different firing characterisitcs) the engine *might* not run properly.
Old Dec 20, 2002 | 07:45 AM
karguy's Avatar
No, it is a Kawasaki!
Old Dec 20, 2002 | 08:35 AM
njmaxseltd's Avatar
A Kawasaki engine in a John Deere? I'm shocked!?!?
Old Dec 20, 2002 | 09:50 AM
karguy's Avatar
It is the Commercial OHV 4 Cycle engine they put in the top of the line mowers. Starts on 1st pull every time, impressive engine. I run AMSOIL 0W-40 Synthetic in it.
Old Dec 20, 2002 | 10:55 AM
sil SE's Avatar
guy likes to make an entrance
Old Jan 14, 2003 | 07:22 AM
Euge82's Avatar
I put in the Champion Platinums last week. The car is running much better which is expected as the OEM plugs had 50k on them. As someone alluded to in a post...wait and see what happens. That is the key question, will I have to replace them in 10-20k miles ? Now I did the work myself so I only have my 2 hours time and $12 invested. There is a local repair shop which is very well run and regarded. It is owned two ex service managers for Honda and Toyota. They use Champion Platinums. I will have to check back in a year.
Rock on ! Visit the Rock and Roll Hall of Fame in Clevelend !
Old Jan 14, 2003 | 07:37 AM
MistaPeerez's Avatar
so whats the best japanese plug..if there is more than one?
Old Jan 14, 2003 | 07:40 AM
Sprint's Avatar
only use NGK in your maxima
Old Feb 28, 2003 | 12:21 PM
gsleve's Avatar
Re: Re: CHampion SPark Plugs, work great!
Interestingly enough a certain repair facility performed this test on the champion spark plugs yet, here is what he said:
Next, we took a 4 cylinder (22R) Toyota truck and installed four different sets of new spark plugs and ran the same test for each set of plugs. All were gapped exactly alike. The results are below:
Type of spark plug KV /electricity|Burn time in milli-seconds
Champion Spark Plugs 1.38 | 1.9
AC Spark Plugs 1.72 | 1.7
Autolite Spark Plugs 1.90 | 1.7
NGK Spark Plugs 1.75 | 1.9
Again the Champions needed less electricity to create and maintain the burn and then they held the spark or flame as long as the NGK and longer than the other two.
I thought this was noteworthy do to the fact that the NGK were the original plugs for this make and model of the vehicle and it seems the champions outperformed the oem without compromise to engine performance.
Additionally when you look at subarus their OEM spark plugs are champion plugs which come from the factory and they seem to perform well for the vehicle
Old Mar 1, 2003 | 08:21 AM
Euge82's Avatar
Champion Spark Plugs update.
While I think that test is interesting. Many of the proponents of NGKs believe that reliability is the key issue. So if you tested both sets of plugs after 30,000 miles, how would they compare.
So far my car is running well. We have about 3,000 miles on the plugs.
Check out the Rock and Roll Hall of Fame in Cleveland ! You can visit the Rock Hall and then walk to Jacobs field to see an Indians game !
Old Mar 1, 2003 | 12:55 PM
Grey00lustre's Avatar
i believe for max ngk or denso are good...i just replace my plugs with oem ngk platinum ones when i had 50k and they work great..
Old Mar 1, 2003 | 01:57 PM
deezo's Avatar
Re: Re: Re: CHampion SPark Plugs, work great!
Originally posted by gsleve
[B]
4 cylinder (22R)B]
You just brought back some memories... I miss my truck.
Old Mar 1, 2003 | 03:49 PM
Lime's Avatar
Awesome post, Tom! 100% agreement here!
Old Mar 1, 2003 | 03:56 PM
Shannon and Ian's Avatar
For about 35 minutes. Till you realize that you need new plugs again. And for gosh sakes do not replace them with Bosch+4's.
Tbone3944
Sep 29, 2015 09:04 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Turbobink
Aug 15, 2015 07:20 AM
1992maximase30
Aug 5, 2015 09:27 PM
maxima297
Aug 3, 2015 12:50 PM
