Sealing Headlights ??
Old Sep 27, 2008 | 01:17 PM
matty's Avatar
I did a Retro and I sealed my lights nice and good, fronts and back and they are still getting condensation in them. Im going to take them off again and goop them up with some more stuff.
What would you recommend me using around the glass and in the rear aroun the projector ??
-matt
Old Sep 27, 2008 | 02:49 PM
wirelessdude04's Avatar
best thing to do is heat em up take em apart. Reseal
Old Sep 27, 2008 | 03:34 PM
matty's Avatar
Well that was my general question. I know they have to be taken apary again, but whats the best thing to use to never have to do this again.
Old Sep 27, 2008 | 03:40 PM
The Russian's Avatar
it might look a little ugly from the top...but if you put a good amount of silicone around it it should be fine...
Old Sep 27, 2008 | 05:56 PM
maxprivate's Avatar
Black Lion
If you use silicone I would make sure it has good bonding ability with plastic. I used silicone and found out the bonding to plastic characteristics was a 7 out of 10 and its peeling away and I also get condensate in my R34'S. It goes away once it stops raining or becomes less humid out. Best thing to use in my opinion would be a good two part Epoxy specifically for plastic, ABS plastic etc. It would also be a lot easy and less messy to buy the 2 part epoxy cartridges that you can insert in to a special epoxy gun that are available... but some of them can get expensive. Luckily I have a company Hilty Epoxy gun which is $75 all I need now is the Epoxy and Im going to remove and reseal mine. Check out the Hilty website if you want to go this route.
Old Sep 27, 2008 | 07:04 PM
Snypa's Avatar
silicone man.spread it real good.
Old Sep 27, 2008 | 07:05 PM
ROCKART's Avatar
wants an I35
yes. silicone RTV. gob that **** on, let it dry and then go back with an exacto knife and cutoff the excess.
worked for my bumper lights.
Old Sep 27, 2008 | 07:39 PM
JtzMax's Avatar
Whatchyou say?
Hot melt glue, then a layer of silicone. At least it worked for me - thus far.
Old Sep 27, 2008 | 08:37 PM
Nismo's Avatar
Shoe goo.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
