Injector problems
Old Nov 6, 2008 | 05:55 AM
jobell's Avatar
Injector problems
I just had #5 injector replaced about a month ago and now I need #3 injector replaced. I'm having my mechanic replace both #3 and #1 injectors since they are located under the intake manifold and it's a PIA to remove. Has anyone tried getting the injectors professionally cleaned when the car starts running rough? If so, does it work or is it a waste of money? What is causing my injectors to fail? They don't have any moving parts!!
Joe
Old Nov 6, 2008 | 06:59 AM
njmaxseltd's Avatar
Age
Joe
Yes they do
You can get them cleaned and flow tested. Worth the $$ ? Up to you.
Try some Techron, use a high detergent fuel such as Shell.
Marvel Mystery Oil might help lubricate them too.
Old Nov 10, 2008 | 05:30 AM
gold96's Avatar
Do the off-the-shelf cleaners do anything?
Having the injectors professionaly cleaned (i.e. taken off first) seems to cost more than just replacing them.
Old Nov 10, 2008 | 07:00 AM
Snypa's Avatar
Replace injectors being that you already started the replacing already.
Old Nov 10, 2008 | 07:54 AM
Nealoc187's Avatar
SLOW
You can have injectors cleaned for $16 a piece at Deatschwerks. Not sure what you guys are paying for new injectors but it might be worth thinking about.
http://www.deatschwerks.com/catalog/...r_services.php
The first time you remove the intake manifold those rear bolts are definitely a pain in the butt so I can understand that if you're not one who generally works on your car then you might end up paying a mechanic a couple hours of labor to remove your injectors for cleaning. Really though, if you have basic tools (wrenches or sockets) you can get it done, the hardest part is just getting your hands back there behind the manifold, getting the wrench on those two bolts, and finding an angle that you can get enough leverage to break those bolts loose.
Maxboy23
55
May 1, 2025 06:09 PM
Mar 12, 2020 12:06 AM
gustavison
Oct 4, 2015 06:50 PM
ajahearn
Sep 19, 2015 03:03 PM
