Magnaflow Y-pipe/Cat Assembly
Old Dec 6, 2008 | 05:55 AM
jlockhart_715's Avatar
I was searching around looking for a new exhaust for my 97 and came across this Magnaflow y-pipe
Anybody seen or heard anything about this set up:
http://www.hopupracing.com/mafrycacoasn.html
Seems a bit expensive, although everything on that site seems expensive, but from the looks of how it is made it seems like that would be an equal length y-pipe with the pre-cats. I didnt find any reviews or links to it here on the org, so I was wondering if anybody is running this setup or has heard anything about it.
Edit: Been looking around on other magnaflow sites and magnaflow.com and cant find this part anywhere else so Im not sure if it is an old part or what.
Old Dec 6, 2008 | 06:11 AM
tigersharkdude's Avatar
its new to me, but with this set up, it looks like you would end up having 3 cats
Old Dec 6, 2008 | 06:19 AM
Ya thats what I was looking at too, not sure if it would still use the factory cat or not but I cant really find any info on it.
Old Dec 6, 2008 | 07:43 AM
Coolsaber57's Avatar
looks like a stock replacement to me?
Old Dec 6, 2008 | 05:17 PM
Thats just a stock replacement. Not worth it.
Old Dec 6, 2008 | 06:28 PM
BLACKonBLACK98's Avatar
Former Vendor
never seen this before.
uhh... wouldn't be too quick to jump the gun there buddy.
a mandrel bent stainless replacement could very well be "worth it". cut out the pre-cats and weld in pipe and you have an equal lenth y-pipe. next issue would be the collector but i'm not sure how important that is.
Old Dec 6, 2008 | 06:43 PM
99BettySE's Avatar
Not to mention if the emissions tests are particularly strict in your area, this way you could stay completely legal and probably still feel an improvement from the mandrel bent piping. Not sure if it'd be worth $500-800 to most people though.
Old Dec 20, 2008 | 04:58 PM
Jin Metsuo's Avatar
Thats stock? cause to be honest i cant even find a performance headers for the maxima if u can find one let me know
Old Dec 20, 2008 | 05:12 PM
MOHFpro90's Avatar
Looks to me like a 90* connector, not a good design if it is.
Old Dec 20, 2008 | 05:52 PM
Nopike's Avatar
Looks like a stock Y=pipe, if that's what you want they can be picked up for much
less.
http://www.rockauto.com/catalog/raframecatalog.php
Although there is no picture for the Walker part #50522 it's very similar to that Magna flow.
Old Dec 20, 2008 | 09:46 PM
G4nismo's Avatar
$519 for that? must be kiddin
Old Dec 20, 2008 | 09:58 PM
MaximaSpd85's Avatar
i can find some.
Old Dec 21, 2008 | 12:27 PM
Maximus681's Avatar
http://www.hopupracing.com/hurnima95peh.html
i think ur getting a y pipe and headers im not sure but thats wat the picture looks like
Old Dec 21, 2008 | 03:38 PM
petro2342's Avatar
$500 isn't worth it to me imo.
Old Dec 21, 2008 | 06:20 PM
Jesse729's Avatar
Is that even going to give close to the same gains as an aftermarket Y-pipe would? Looking at the pic it looks like the right bank comes in at a 90 degree angle which probably restricts the flow just like stock.
I've never heard of anyone not being able to meet emissions without the pre-cats. Just get a Warpspeed for $200
Old Dec 22, 2008 | 05:43 PM
Forgot all about this thread...
I emailed Magnaflow a while back to get some info from them about the assembly it seems basically like a stock replacement, they claim that their cats flow 40% better than stock. No dyno numbers as they don't dyno their cats. I have no intention of buying this because it does seem way to expensive for what it is.
Here is another pic they sent me of the assembly, the right side bank does seem to attach at a 90 as well:
Old Dec 22, 2008 | 05:52 PM
Told you it was stock.
Old Sep 18, 2012 | 12:54 PM
mikeg75's Avatar
RockAuto now has the Magnaflow y-pipe for $470 or so, and I'm probably going to pick it up, so that my car remains stock, and I have no problems passing emissions tests, which tend to be strict in Philadelphia. I'll probably also get a Magnaflow direct fit Cat, to go with it.
To be honest, I don't care or need the performance gains that occur at high RPMs with an aftermarket y-pipe that has no pre-cats, because I really only care about acceleration in the low RPM range, like getting onto the highway.
I had debated about getting a non street-legal y-pipe but with my maxima being a family car, it just doesn't make sense.
Old Sep 18, 2012 | 12:57 PM
Toxic!'s Avatar
4DSC*
Old Sep 18, 2012 | 01:13 PM
ShocknAwe's Avatar
If you refer to a max as a family sedan that can never attain good performance then you dont know much about the VQ engine and have little imagination. The suspension will obviously never compete with independent rear suspension platforms but the solid beam has its advantages as well. Its far from a grocery getter with the right mind behind it
Old Sep 19, 2012 | 04:35 AM
mikeg75's Avatar
In my case, having 2 kids, commuting to work by walking or biking, and only using the car on weekends or after work for errands and such, it is a family car. I've maintained it extremely well and it's got a bunch of new parts, but none are performance enhancing. At this point, I just want to keep it running as well as possible and get some more years out of my car.
Also, compared to y-pipe performance gains from taking out the cats and having a smoother bend, my understanding is that the backpressure provided by the 90-degree bend helps with low-end torque, which to me is preferable to high-end torque, because I'm not racing around town in 1st or 2nd gear just to have an extra kick, and on the highway, if I'm pulling onto an onramp or just cruising, I want that extra torque at the low end to get me safely where I need to be.
Old Sep 19, 2012 | 05:21 AM
01bluemax's Avatar
i didn't notice any torque loss. i actually gain speed faster, and can merge into traffic better w/ the pipe. I also find it easier to break the tires loose when i'm sitting still.
Old Sep 19, 2012 | 10:34 AM
VQ'rInWLA's Avatar
Justin Kroll
Oct 1, 2015 07:03 PM
atriuum
Sep 28, 2015 01:19 PM
Noela
Sep 26, 2015 08:22 AM
Maxboy23
Sep 4, 2015 06:04 PM
Justin Kroll
Sep 2, 2015 11:06 AM
