strange high pitched noise from the engine. Changed all belts still there confused.
i chenged all the belts and its still there like a lill mini supercharger noise. my maitenence is good everything new. never had it before untill now any clue im so long. checked the cold air intake checked every little thing but just cant figure it out. any one have any clue?
found it on youtube not my car but almost exacly wt it sound like how do i get rid of this ****?
http://www.youtube.com/watch?v=_Jl_fx5JFDw
Do you mean as far as overall maintenance? Follow the maintenance schedule and give it a look over for anything else that may need to be done.
Have you tried taking the belts off and spinning all of the pulleys by hand? It most likely is the tensioner pulley.
That or you could use the screwdriver method to pinpoint the location.
If your worry was that the belts were never changed, and you changed the belts...what else do you mean?
Take a screw driver and pin point where you think the noise is coming from. Put your ear on it and see if you get any vibration or sound out of it. If you get nothing try another place until one of the 2 happens.
There are several other bearings on the belt such as the alternator bearing and the AC compressor clutch bearing. But they are turning so different method is used to isolate those. The screwdriver method works for the tensioner bearing.
Hell, the pulley alone is $41.95. You could press out the bearing and find a replacement, but it'll probably be a PITA to find the correct one.
$18.49 at Rockauto for a new pulley - http://info.rockauto.com/FourSeasons...html?45004.jpg
sdotcarter
Sep 2, 2015 09:53 PM
Justin Kroll
Sep 2, 2015 11:06 AM
