Tachometer doesnt work...
Old Feb 10, 2009 | 03:31 PM
MOHFpro90's Avatar
My tach reads 0 rpm all the time and I cant figure out why. I tried a new tach, no avail. I have one code: IACV (I am not running one, due to the temporary 00vi setup).
Any ideas?
Old Feb 10, 2009 | 03:52 PM
Kevlo911's Avatar
Kevlo for President
Check ECU pin5.
Old Feb 10, 2009 | 04:15 PM
G4nismo's Avatar
check power supply b/t terminal 41 and ground on M84 connector.
if not good, check fuse #13 in fuse block
check ground for the tach. continuity should exist b/t terminal 31 and ground on M83 connector.
check for voltage change b/t terminal 17 and 31 @ idle and 2000rpm(just guestamate).
voltage should change w/ rpm, higher rpm-higher voltage.
also, like kevlo said, check pin #5 of ecu. w/ the engine running at idle, voltage should be around 7V b/t pin5 and ground (#25 is eccs ground)
Old Feb 10, 2009 | 04:55 PM
MOHFpro90's Avatar
Thanks a bunch guys. I found this in the FSM right after I posted... -.- Anyhow, ill let you know how it goes.
Old Feb 10, 2009 | 07:34 PM
G4nismo's Avatar
yeh, kinda surprised you would post something like this cause i know you gotta have the FSM
Old Feb 10, 2009 | 08:11 PM
MOHFpro90's Avatar
Yeah well, after reading that part of the FSM, it basically said I have a bad ground, bad tach or bad ECM.
Seeing that the tach just stopped working one day(it worked when I turned the car off, next time I turned it on it read 0) I guestimated it wasnt a bad ground. And its not the tach itself. So that leaves the ECM, which I dont think would only have this one issue with it...
Thats why I was asking if there were any other possible causes. But I will run through the checklist to see if anything comes up (i.e. short, ground etc).
Old Feb 10, 2009 | 08:23 PM
Kevlo911's Avatar
Kevlo for President
Got any friends with a spare cluster?
Old Feb 11, 2009 | 07:13 AM
MOHFpro90's Avatar
I has a spare cluster
But it has no speedo. Would this affect the the tach at all?
Old Feb 11, 2009 | 07:36 AM
Kevlo911's Avatar
Kevlo for President
Nope, infact you can swap out the tach, it is held in by 4-5 signal screws and that's it.
Old Feb 11, 2009 | 07:46 AM
pmohr's Avatar
No more Maximas...
Actually, I believe he already tried that.
I still vote checking continuity from the cluster back to the ECU.
Got me all worked up in PM and it's taking forever
Old Feb 11, 2009 | 07:47 AM
Kevlo911's Avatar
Kevlo for President
Oh, then try to force ground it and run a wire from ecu
Old Feb 11, 2009 | 08:01 AM
G4nismo's Avatar
did you tamper w/ the ecu lately? maybe one of the wires loosened (relevant to the tach)
out from the HS. dunno, tell us what you find
Old Feb 11, 2009 | 08:14 AM
MOHFpro90's Avatar
Omfg.
I swear. I hate this 00VI. The RPM switch, SOMEHOW, was causing the tach signal to read 0.010 - 0.011 V the whole time through the rpms. I disconnected it, and voila!
I mean, seriously...I used a wire tap to tap the thing. WTF
Old Feb 11, 2009 | 09:09 AM
G4nismo's Avatar
Omfg.
to which source did you have the rpm switch hooked up?
Old Feb 11, 2009 | 12:17 PM
MOHFpro90's Avatar
The #5 wire in the ECM harness...basically, I tapped the wire from the ECM to the tach.
Old Feb 11, 2009 | 01:30 PM
G4nismo's Avatar
well i have my switch tapped into the ecu as well as the suprastick w/ no issues
Old Feb 11, 2009 | 03:10 PM
MOHFpro90's Avatar
I think my Summit itself may have shorted. I am going to investigate it a little more.
Old Feb 11, 2009 | 04:14 PM
Omfg.
MEVI + Harlan switch FTW lol
Old Feb 11, 2009 | 07:22 PM
G4nismo's Avatar
00vi + MSD digital switch >>>>> mevi + harlan
true story
DO IT wiz! you gainz moar powers!
Old Feb 11, 2009 | 07:23 PM
pmohr's Avatar
No more Maximas...
true story
USIM + [blank] FTW!
Old Feb 12, 2009 | 09:45 AM
G4nismo's Avatar
Originally Posted by pmohr
USIM + [blank] FTW!
Ha, i lol'ed a little
Old Feb 12, 2009 | 06:56 PM
MOHFpro90's Avatar
Dont Lie. You didnt.
Old Feb 12, 2009 | 06:57 PM
pmohr's Avatar
No more Maximas...
Old Feb 12, 2009 | 07:59 PM
MOHFpro90's Avatar
Oh right now, I think USIM might be less frustrating than this thing...
MR2 T'd
Jul 9, 2021 05:06 AM
jchronis2552
Sep 21, 2015 05:52 AM
magneto112
Sep 10, 2015 12:52 AM
tnewbs
Aug 28, 2015 10:15 AM
criminalslang810
Aug 16, 2015 08:12 AM
