Got 0509, replaced O2, then got both 0509 and 0115
Old Feb 18, 2009 | 04:03 PM
t65k3's Avatar
Still Learning
CEL was on, ECU gave me a 0509 two days ago. Had a shop to replace the front heated O2 sensor for me today.
15min of driving, CEL was on again. Now it's 0509 and 0115.
After a bit for search, found this useful thread,
http://forums.maxima.org/4th-generat...ease-help.html
Now I am suspecting it's not just the O2 sensors. It might be one of the possible causes,
- Intake air leaks
- Defective Front Heated Oxygen Sensor
- Fuel injectors
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Faulty Mass Air Flow Sensor
This all started in about 20min after I put in a new tank of gas. Would it be caused by bad gas? Any suggestion?
Does anyone happen to know the reasonable price for a heated sensor?
Thanks.
Old Feb 19, 2009 | 07:51 AM
t65k3's Avatar
Still Learning
http://forums.maxima.org/4th-generat...ms-fix-me.html
found this one with search "P0171"
since both banks have the codes now, I guess MAF is my best bet at this moment.
Old Feb 21, 2009 | 01:53 PM
t65k3's Avatar
Still Learning
Had almost everything I read about thie issue checked ......
Plug in new O2......
But the code is still there containing 0509 and 0115......
When scanning with OBD II, P0174.... running lean.... voltage on the right bank was not changing much, stayed at ~0 the whole time......
Though the left bank had a new O2 and the voltage was changing in response to the gas I gave, there's still 0509......
This whole problem happend 20 min after I got full tank of gas from Walmart about a week ago. It was about 2/5 of tank gone this morning, so I topped it off with good Shell gas..... Man, 12MPG, suddenly I got a V8.......
Next thing to do: check if there's smoke coming out of pipe....
I am gonna need some luck......
Old Feb 21, 2009 | 03:34 PM
Carrera's Avatar
could be an intake leak. have the car running and spray carb cleaner or brake clean around the intake manifold seals, upper and lower and if the idle fluctuates, then thats your problem. Worth a shot
Old Feb 22, 2009 | 03:36 PM
maxima_million's Avatar
Ok, this is wierd: I too pulled 0509 and replaced the front 02 sensor. About 10 days after, the 'Check Engine Light" came on and I pulled 0509 AND 0115. Today it took 3 tries before the engine turned over and I smelled raw fuel as well. I have not tried any of the suggestions mentioned on this thread but plan on doing so maybe next weekend!
Thanks in advance for those who are troubleshooting this as well!
Old Feb 23, 2009 | 01:31 AM
t65k3's Avatar
Still Learning
at least, you enjoyed 10 days without worries.....
My second 0509 along with 0115 came up only minutes after I replaced O2 for first 0509.......
I heard hissing sound when the engine's running. I kind of noticed that before but didn't pay attention. Maybe there's some leak somewhere I overlooked......
I need to get a new MAF, because it kind of makes sense to me..... if MAF goes bad, both O2 will detect something weird......
Old Feb 25, 2009 | 10:18 PM
t65k3's Avatar
Still Learning
Replaced both O2s.
Still got the code for some reason.
Cleared it.
No code so far. It's been almost a day.
But I can tell it's still dumping too much fuel by the smell....
And... I am almost sure the code will come back.....
The output of front O2 is not changing much.
When I hit the gas and maintained around 2000rpm. it started to work like the scanner said, "between rich and lean. 5 times/ 10second"
When rpm drops, it stopped again.
Any suggestion?
Old Mar 2, 2009 | 02:40 AM
t65k3's Avatar
Still Learning
Originally Posted by t65k3
Replaced both O2s.
Cleared it.
Any suggestion?
Weird.... CEL has not been on for four days, voltage for O2 reading was not quite right for the time that I cleared the code. I have only replaced one O2 sensor.....
Old Mar 8, 2009 | 12:21 PM
t65k3's Avatar
Still Learning
CEL came back on after 1 week of peace...... 0509......
Check Secondary Intake valve?
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
