side mirror removal help
The door? There's absolutely no reason you'd remove the door itself. Not like it'd help at all, anyway.
Search was pretty clear for me
http://forums.maxima.org/4th-generat...ew-mirror.html
http://forums.maxima.org/4th-generat...de-mirror.html
And so on.
And so on.
hmm well im about half way done getting the door off and came back in here to see if anyone said anything else. i guess i'll just take off the door panel and get the whole mirror off that way. I'd be a little nervous taking the actual mirror off
And if it is just to get the painted part out -
Then, just pry out the mirror (the glass with it's plastic backing) using screwdriver like a crowbar, it snaps fits into a ball joint - you can snap it back in once done. It takes some force, and there will be a snapping sound as each snap is released, but trust me, if you do it correctly, nothing should break.
Put a cushion underneath to catch the mirror incase it falls out (I have broken a mirror this way once).
Once the mirror is out, you can access the screw that holds the painted part to the mirror sub-asssembly.
The Frye
09-02-2021 11:03 AM
03-12-2020 12:06 AM
flu2000
09-08-2015 02:23 PM
