Intermittent Engine Problem
Old Mar 24, 2009 | 10:58 AM
ghost1's Avatar
Hoping someone has an answer. 99.5 SE-L Automatic. 130kmiles. Have intermittent hesitation that cannot be isolated. No codes, not consistent, will run fine then every so often have the hesitation. Normally at slower speeds, starting from stop but again is not consistent. Have new spark plugs, compression is good...possible coil packs? My mechanic has had it for 3 days now and has had it hooked to computer. Has driven and been able to duplicate issue however does not send code through computer. Even TSB's are blank. If anyone has had same problem and found cause would appreciate feedback...
Old Mar 24, 2009 | 11:45 AM
njmaxseltd's Avatar
It's a 99, most likely a slight misfire from a weak coil pack.
Give it some time, it will either fail altogether or finally throw a code.
Had the same issue with my 99 way back. Took a whole summer to finally throw a misfire code.
Good luck!
Old Mar 24, 2009 | 11:48 AM
Its a coil pack. Test them and figure out which 1 it is.
Old Mar 24, 2009 | 11:52 AM
IlyaK's Avatar
The Golden One
Good luck!
+1.
Put 96 coils in I got from EBay and car purrs.
Old Mar 24, 2009 | 04:58 PM
pmohr's Avatar
No more Maximas...
I'd just replace them all, personally.
Old Mar 24, 2009 | 05:52 PM
IlyaK's Avatar
The Golden One
+1.
I replaced cylinder one because that's where my misfire was. Still had drivability issues with no pending or clear CEL. Replaced the other 5 and been good.
MAXSE5SPD
Sep 17, 2022 04:00 AM
6spd4dsc
Mar 4, 2016 05:19 PM
jfl330
Sep 4, 2015 01:44 PM
TheMafia
Sep 4, 2015 08:26 AM
A32goldylocks
Sep 2, 2015 06:39 AM
