Door Hinges seem weak? Sags a little.
So maybe because the car is old, or could be the chassis but I honestly kinda doubt it. The door sags a tiny bit just enough to hit the locking portion. I went to try and see if it is a bad hinge and it seems like it is it. I can move it up and down and feel some play.
Can these be repaired or do I have to replace them? Where can I find them for a good price? Rockauto does not have them. Is this common for our car?
Do you think it is the bracket bolt? because I think the pin is where it is coming from. I dunno. Can you tighten or adjust the pins? I doubt it. I guess I will try your suggestion I was gonna try that as well to be sure.
It's at the front of the door. There is a hinge on top and bottom. Each one has two bolts. I tightened though. My driver side door improved but still had a slight issue. But it definitely improved.
They are the hinges and Pins, come as one unit, that are the problem. Do search and there are plenty of threads on this. I have the same issue and just havent really taken the next step to order them from nissan. Cheap ?? Definetly not cheap, try $35 a hinge and you need to remove the fender to replace them.
-matt
-matt
-matt
-matt
Thankfully I didn't have to do that. Tightening them worked for me. My previous car (that had this issue) was salvage so probably wasn't as tight after being fixed.
Good luck.
-matt
-matt
but yeah, that sucks you have to take off the fender. I need a new one on my pass side. At least those are mad cheap. lol
REDinLV
08-15-2024 12:30 AM
magiconthetire
10-26-2015 09:03 PM
trsandrew
10-25-2015 02:47 PM
Need help
23
10-02-2015 08:56 AM
