Ignition coils...shuddering at stop when in Drive, etc
Old May 25, 2009 | 07:25 PM
ZachAJ's Avatar
Hey all,
I have the problem I've seen a lot on the forums...at stops, the car shudders randomly every few seconds when in Drive/Reverse but not in Park or Neutral. It only occurs once the engine has warmed up, not when it's cold. Also has some hesitation and studdering at certain rpm points. At first I tried changing fuel filter, air filter, spark plugs, cleaning throttle body/IACV, etc. Then I came to these great forums and saw that it was most likely the ignition coils.
My problem is that I have replaced 3 ignition coils and it hasn't helped. They are 2 rear and 1 front, and I have tried moving them in every combination to fix it. I don't want to spend another >$200 to replace all 6, but is it likely that they are all bad, or that it is something else?
The car's bone stock, everything else is working fine.
Thanks!
Old May 25, 2009 | 07:52 PM
pmohr's Avatar
No more Maximas...
What year? Any codes?
FWIW if all of your coils are bad, then only a whole set will fix the problem. No need to spend $200, you can get them much cheaper used.
Have you tested them? The procedure for that is found through search.
Old May 25, 2009 | 10:28 PM
ZachAJ's Avatar
1996, no codes...well, I don't have check engine light, but I do get 0325 with my ScanGauge.
I did just notice from a search on the forums the magic of eBay Motors with ~$25 coils....can't believe I paid full price for 3 of them already!!!
I did the resistance testing and got the same result for all of them.
Old May 26, 2009 | 12:32 AM
AndrewR2442's Avatar
in all of my testing i have yet to find a valid test for "intermittent" (sp?) failing spark plugs with a multimeter. FWIW Certain shops have better equipment that will test the spark plug better. I took my car there and they actually told me which two coils are failing. Replaced them and now i'm problem free for 3 months.
Old May 26, 2009 | 05:08 AM
nymax99se's Avatar
i replaced 4 ignition coils recently and the other 2 are original......and the car is riding sluggish on acceleration.....can it be possible that the other 2 are done and will not pop up a check engine light?
Old May 26, 2009 | 11:30 AM
ZachAJ's Avatar
Air assembly question
Hey, I just noticed something else odd. I have a vacuum hose that attaches to nothing...See where my finger is pointing?
I checked courtesy nissan's parts site, and it says I need some sort of resonator, but there is no hole in my air duct assembly to plug into...I'm talking about 16580R at http://www.courtesyparts.com/maxima-...1800_1803.html
Is this random hose connecting to nothing normal?
Old May 26, 2009 | 11:41 AM
pmohr's Avatar
No more Maximas...
Holy massive inline. Scale down, hmm?
Did you not follow the line down to where it starts from? Is it not the trans breather?
You can see your scoop was designed for that secondary (well, tertiary, really) resonator, you must have a later model resonator (primary) in there.
Actually, FAST shows that resonator only being there in 02/94-07/95.
Old May 26, 2009 | 12:15 PM
ZachAJ's Avatar
Scaled down.
So it does look like it's coming from the tranny...so some mechanic switched resonators on me? sigh... Is this an important part, or is it OK to leave?
Old May 26, 2009 | 12:19 PM
pmohr's Avatar
No more Maximas...
Scaled down.
Depending on your build date, it may just be how it is. Again, FAST only lists that resonator up to 07/95.
It doesn't matter, it's essentially just for sound.
Old May 26, 2009 | 12:48 PM
ZachAJ's Avatar
Awesome.
Well, after reading several other threads with people having similar stumbling @ stops in drive and during some accelerating, I'm going to clean the engine grounding screws on the intake, the MAF sensor, and check the crank sensor. If that doesn't work, I'll buy the new KS and coils. Will let everyone know how it goes.
Old May 26, 2009 | 05:43 PM
ZachAJ's Avatar
Of course, the easy things are not the solution. I cleaned the MAF (looked fine beforehand), and the screws (also looked good as new). I'll buy the new KS and 3 new coils. My symptoms definitely get worse when it gets hot though.
Old May 26, 2009 | 06:12 PM
cobradb's Avatar
man tran have a breather like that
Old May 26, 2009 | 06:19 PM
pmohr's Avatar
No more Maximas...
...as do the autos.
Assuming 'man' is some form of shorthand for manual, saving you from typing a whole 3 letters.
Old May 26, 2009 | 07:37 PM
ZachAJ's Avatar
Also, it was manufactured 5/96, so yea, that explains the lack of resonator. One less piece of plastic for Nissan to make.
Old May 26, 2009 | 09:59 PM
speed3000gt's Avatar
Let us know your results....good luck
Old May 26, 2009 | 11:02 PM
EsQueue's Avatar
If your coils need replacement PLEASE don't buy them from ebay seller AIRflowtech or you are in for a world of hurt.
http://forums.maxima.org/4th-generat...j-warning.html
Sorry for spamming this but I don't want anyone here getting screwed like I did.
Old Jun 1, 2009 | 04:55 PM
ZachAJ's Avatar
Hey all,
I just replaced the 4 coils I hadn't already, and the knock sensor. Good news: car feels better, but I don't want to jinx it before I go for a long ride on a hot day. The knock sensor P0325 also went away.
Bad news: I get a P1320 error now. The car feels good...is this common with the cheapie eBay coils, or is one of them actually bad?
fastcarny
Oct 6, 2015 10:42 AM
rnb754
Sep 14, 2015 11:39 PM
crazyespn
Sep 3, 2015 01:30 PM
