Interior dash lights problem
Old Jun 5, 2009 | 04:02 PM
SwEEt_tOOtH's Avatar
Hey guys... Ever since I bought my car I've noticed that my auto climate control lights don't turn on. Actually, they've probably randomly turned on like 3 times since I bought the car. The only thing that stays lit up is the screen but the buttons don't light up. The hazard lights button and rear defrost button turns on sometimes as well and the lights indicating what gear shift you're on NEVER turn on (P-R-N-D-L-2-1).
I've checked the fuses and they all seem fine unless I skipped one. What should I check for?
My car is a car theft recovery and the idiots that stole the car completely sliced off all the wiring in the back instead of just unplugging the harnesses. So I had to wire some of the stuff back up in order to get everything working again. So is there a cable I should look out for?
Any help would be greatly appreciated.
Old Jun 5, 2009 | 05:35 PM
pmohr's Avatar
No more Maximas...
It likely is indeed all in the wiring.
There's no specific 'cable' you should be looking for, just give everything a look over.
Do the lights come on if you shake the dash harness around?
Old Jun 5, 2009 | 08:37 PM
tosheto's Avatar
It might be bad connection - some cable might not be soldiered well. Or maybe the plug itself it not put tight on the back
Old Jun 6, 2009 | 09:11 AM
I'll check it again today after work.
Old Jun 6, 2009 | 05:33 PM
RE5TO81's Avatar
check out this site...
www.petah.org/maxima/hazard
maybe you find some help...
Old Jun 6, 2009 | 06:21 PM
Mistertones's Avatar
ahh mine does the same thing!!! My climate control buttons ALL of them won't light up. This is after I installed my Pioneer DVD player. Any recommendations? I checked all the wiring and fuses. and i'm left clueless..
Old Jun 6, 2009 | 06:29 PM
pmohr's Avatar
No more Maximas...
You have checked the dimmer switch, correct?
Have you checked for power at the illumination wire going to the climate control unit?
Old Jun 6, 2009 | 06:44 PM
matrix11229's Avatar
It happened to me too after I installed Pioneer mp3 player.
I pulled the middle console out and found that some bulbs fell out and some were dead.
I pulled the bulbs out and installed leds inside bulb bases.
Old Jun 6, 2009 | 09:00 PM
Which one is the illumination wire?
Matt93SE
May 24, 2019 02:58 PM
Roymg
Sep 3, 2018 05:10 AM
AnsonJ
Jun 2, 2017 01:35 PM
homeyclaus
Sep 3, 2015 06:15 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
