2nd stage on key ignition gets no power
The normal ignition has 3 spots.. standy, 2nd stage, and start. Normally, once you turn it to start it falls back to stage 2 after the car is started.
2 on my ignition has no power to anything..cant roll up windows, use radio or lights on 2. Is there a fuse/relay for this or is the ignition itself messed up???
To avoid confusion, there's no 'standy' (?) or '2nd stage'. There's accessory, ignition/on, and start.
First step, have you even checked any fuses yet? That is the first thing you should've done, before even bothering to make a thread. Takes 30 seconds, and is likely your problem.
It's either fuses, wiring, the ignition switch itself, or the ignition relay.
James92SE
142
01-02-2024 09:23 AM
pears
09-18-2015 05:25 AM
