Installing an Altenator 99 SE-L
Alternator replacement
I did this and you need to do it from underneath.
Remove the plastic cover. Release belt tension and make sure belt is loose.
Remove the A/C compressor bolts, don't take the hoses off, hoses are rubber so it will swing out of the way.
Alternator can be unbolted from on top and underneath and removed.
No need to remove radiator.
You post whored to make this thread?
Had you searched, you wouldnt've 'needed' to post meaningless crap in other people's threads. When I say 'meaningless crap', I mean this:
Now, as for searching, you would've found this:
http://www.motorvate.ca/mvp.php/500
http://forums.maxima.org/4th-generat...placement.html
http://forums.maxima.org/4th-generat...nator-r-r.html
...etc.
Hell, the instructions are in the stickies:
http://forums.maxima.org/4th-generat...on-maxima.html
Might I mention the following:
...etc.
If you ask a question and the answer can be found in the FAQ threads, your thread gets locked.
http://forums.maxima.org/4th-generat...king-rule.html
MaxLife17
Jun 27, 2019 01:37 PM
