Are 5th gen maxs faster than 4th gen ??
Old Aug 10, 2009 | 02:29 AM
  #41
kzoosho's Avatar
Originally Posted by Christobal65
Well i think that's faster than my VR-4 since its pretty much stock lol
I should have new numbers soon also.
Old Aug 10, 2009 | 05:06 AM
  #42
Nealoc187's Avatar
SLOW
In a drag race the lighter weight of the 4th gen is an advantage, however ultimately a 5th gen would end up eventually pulling ahead if the race were long enough. Depending on options and model year and such the weight difference can end up being upwards of 300-400lbs.
Old Aug 10, 2009 | 05:23 AM
  #43
aackshun's Avatar
Thought so....
Old Aug 10, 2009 | 12:38 PM
  #44
Christobal65's Avatar
Perhaps if you take a GXE 4th gen with a 5spd and compare it to a GLE 5th gen with an auto, but thats not really a fair comparison is it? All else being equal (ie GXE vs GXE) the weight difference should be no more than 200lbs.
you gotta compare apples to apples other wise you are just skewing facts to make your side look better. From personal experience my 01 SE AE is faster than my moms similarly equipped 96 SE, both cars are 5spds.
Old Aug 10, 2009 | 01:28 PM
  #45
ColombianMax's Avatar
Well, gotta make sure the 4th gen GXE is still a GXE, I've got just about every option an SE has and then some more, EXCEPT sunroof and digital climate
Old Aug 11, 2009 | 09:48 AM
  #46
Nealoc187's Avatar
SLOW
Your claim is incorrect.
A 4th gen GXE 5spd is a 2880-2930lb car. A 5th gen GXE 5spd is a 3150-3200lb car (3150 is even being generous on the light side according to the listed weights on websites such as NADA.com and Edmunds.com). Apples to apples. Furthermore, if you read my statement again I said the weight difference can be upwards of 300-400lbs, not that it is always upwards of 300-400lbs. The weight difference can be that high and often is, not always, but often. That's not skewing the facts, that's stating the facts.
Like I said before, 4th gens are generally a few tenths quicker in a 1/8 or 1/4 mile drag race due to better tq/weight ratio, less rotational mass (lighter wheel/tire combos) etc. 5th gens will take over once the speed really gets up there because power to weight ratio matters less and less at higher speeds, where overall horsepower and aerodynamics take over (assuming equal gearing, which 4th and 5th gens have). In a drag race I'd rather be in a stock 4th gen. In a highway race I'd rather be in a stock 5th gen.
Old Aug 11, 2009 | 10:01 AM
  #47
B_Eaze's Avatar
A 4th gen GXE 5spd is a 2880-2930lb car. A 5th gen GXE 5spd is a 3150-3200lb car (3150 is even being generous on the light side according to the listed weights on websites such as NADA.com and Edmunds.com). Apples to apples. Furthermore, if you read my statement again I said the weight difference can be upwards of 300-400lbs, not that it is always upwards of 300-400lbs. The facts are those. The weight difference can be that high and often is, not always, but often.
Physics prevails..... there you have it. Any idea why from a design stand point you would make the car heavier?
Old Aug 11, 2009 | 10:11 AM
  #48
Nealoc187's Avatar
SLOW
More sound deadening for a quieter ride, more structural integrity for crash worthiness, more structural stiffening for smoother ride (stiffer chassis means the suspension does it's job more effectively rather than the body of the car flexing, and of course more options like navigation systems, more airbags, more dense/less plasticky interior material, etc.
Old Aug 11, 2009 | 11:40 AM
  #49
A 4th gen GXE 5spd is a 2880-2930lb car. A 5th gen GXE 5spd is a 3150-3200lb car (3150 is even being generous on the light side according to the listed weights on websites such as NADA.com and Edmunds.com). Apples to apples. Furthermore, if you read my statement again I said the weight difference can be upwards of 300-400lbs, not that it is always . The weight difference can be that high and often is, not always, but often. That's not skewing the facts, that's stating the facts.
I cant find any facts that support your 2900lb 4th gen claim...the lowest i could find was 3001lbs on on a 95 GXE 5spd. The heaviest i could find for a 5th gen was 3294lbs on a GLE Auto. Unless I'm mistaken that's 293lbs not 400lbs and as far as I could tell its impossible with out weight reduction the 4th gen for there to be a 400lb weight difference. The listed weight difference between SE vs SE and when you compare GXE vs GXE is less than 200lbs. In fact your own 'facts' dont support a claim of up to 400lbs.
Look I wholeheartedly agree that the performance of stock 4th and 5th (DE-K) gens is nearly identical and should you line two perfectly healthy cars up the difference would be the driver not so much the cars. I have a good amount of experience with both 4th gens, my moms since 97, and now my own 5th gen. Both are great cars and are very similar and yet very different.
Old Aug 11, 2009 | 11:55 AM
  #50
kzoosho's Avatar
Do more research then report back. I know for a fact that there are light 4th gens without taking any weight out. Neal has been around max's for years trust me. Take a little more time reading and you should find out that 4ths can very well be light as ****. BTW he has the quickest stock 4th gen lol and its a beater.
Old Aug 11, 2009 | 12:20 PM
  #51
PetitFrereMaxima's Avatar
5th gen is faster. Period. Same stock model side-by-side.
Old Aug 11, 2009 | 12:34 PM
  #52
maximized98's Avatar
Addicted to the Org
Can a 2 legged man run faster than a 1 legged man?
Old Aug 11, 2009 | 12:42 PM
  #53
RacerX1320's Avatar
Can we re-name this thread the "what if " thread?
* Yawn
  #54
timmay5835's Avatar
In my world 4th gens are faster
Old Aug 11, 2009 | 01:19 PM
  #55
Nealoc187's Avatar
SLOW
Making blanket statements like that just makes you look foolish.
Old Aug 11, 2009 | 02:12 PM
  #56
Nealoc187's Avatar
SLOW
If you could not find any facts then you didn't search very hard at all, because I brought up about 15 threads in a single search in which many, many people list their 4th gens at under 2900lbs without driver. My two stock 4th gens included, I have weighed my 4th gens over the years on probably 6-8 different track scales and a landfill scale and a scrap yard scale, all weights were consistent with 1/4-1/2 tank of gas (that's what I usually run at the track). Not outlying data points or inconsistencies to speak of, maybe 10 or 20lbs here or there but nothing to get in a twist over. Full tank of gas would add another 40-50lbs or so.
If you'd rather go by published weights though, the published weight of the 95 and 96 5spd 4th gen was 2886lbs on both Edmunds.com and NADA.com when they used to list it, it was spot on. So based on that I am admittedly make the assumption that the weights for 5th gens were similarly accurate back when they used to list them, and said weights were:
GXE - 3186 lbs.
GLE - 3294 lbs.
SE - 3199lbs.
(source: http://forums.maxima.org/5th-generat...le-debate.html )
3294-2886 = 408lbs. Heaviest to lightest. You take the GLE out of the equation and you end up with a 300lb spread when comparing as you said, apples to apples. As I've clearly demonstrated though, the weight difference can be upwards of 400lbs. Thus my earlier comment that said "the weight difference can be upwards of 300-400lbs." I don't have any published numbers for 99 GLEs as I frankly never cared about the weights of autos, never bothered to look up the figures. So it's entirely possible that the heaviest 4th gen could be just as heavy as the lightest 5th gen, I really don't know, but I stand by my statement that the weight difference between a 4th gen and 5th gen is up to 400lbs, lightest to heaviest.
I think we're both in agreement though that they are both great cars, both with their own merits
edited: to more accurately reflect more research I just did on the weights I listed for my own cars, searched some more old posts....
Old Aug 11, 2009 | 04:58 PM
  #57
big long post
Oh see i don't ever go by 'weights' given on any forum cause most of the time its rubbish (wait did i just say rubbish...damned Harry Potter anyways). I mean you cant really follow what forums say about the weight of 3000GT's cause forums tell you that all 3000GT's, including the FWD base, weigh 4200lbs when in reality the only 3000GT that weighed in at close to that was the VR-4 Spyder which weighed in at a hair under 4100lbs. Also forums have a nasty habit of quoting GVRW as car weight.
I didn't search here i went straight to Cars.com and edmonds.com and both of them stated that the lightest 4th gen was about 3000lbs. I tend to use them because they tend to list the published specs from the mfg and are somewhat impartial. Since as we've seen in this thread we all have trouble doing lol
Yeah ok great research and such a well written post....
* Yawn
aww come on thats what makes bench racing so much fun
Old Aug 11, 2009 | 05:19 PM
  #58
Product_Of_Korea's Avatar
If a tree falls in the forest and no one is there to hear it does it make a sound
Old Aug 11, 2009 | 05:29 PM
  #59
Depending on the definition of 'sound' you use the answer is no
Old Aug 11, 2009 | 05:47 PM
  #60
But what if i stick a microphone out there
Old Aug 11, 2009 | 06:24 PM
  #61
BLACKonBLACK98's Avatar
Former Vendor
less slow = faster?
Old Aug 11, 2009 | 06:40 PM
  #62
maxgtr2000's Avatar
KH3 by popular demand
Power to rate ratio between the gens is a factor. If the 5th gen is heavier does it have enough horses to make up the extra weight vs the 4th gen? One reason why track cars dump the sound deadening, go to fiberglass bodies and hoods, etc. A vq35 in a 5th gen and a vq35 in a 4th gen are 2 different animals because of power to weight ratio.
Old Aug 11, 2009 | 08:37 PM
  #63
maXspeed96se's Avatar
Old Aug 11, 2009 | 10:38 PM
  #64
Indeed but once you start talking mods which car is faster comes down to the person with deeper pockets.
Old Aug 11, 2009 | 10:55 PM
  #65
cfiggs's Avatar
That would be helpful if that had anything to do with this thread, we're talking stock 4th gen and 5th gen, and it would be fairly close because the power to weight ratio is very similar and no one has specified what they mean by faster.. are we talking quarter mile, eighth mile, whole mile? These are all factors that will determine what will answer the op question on which is faster, no one will know unless you had the same driver do 3 runs with each car in whatever length you want to determine which car is faster same model, same drivetrain. Personally I don't think it matters because for the price of a 5th gen I can have a 4th gen that will walk your 5th gen, and for the price 5.5 gen I can have a 4th gen that will walk that too.
4th gen ftw!!
Old Aug 11, 2009 | 11:03 PM
  #66
MoncefA33's Avatar
Neal's stock 4th gen is the fastest.
/thread.
Old Aug 11, 2009 | 11:07 PM
  #67
98GleMax's Avatar
5th is def faster lol........i got a 4th and its quick but not like a 5th...
Old Aug 12, 2009 | 06:20 AM
  #68
ampire's Avatar
My 4th gen SE consistently impresses me given how modest the horsepower and torque numbers are on paper.
Old Aug 12, 2009 | 10:26 AM
  #69
4th gen ftw!!
Clearly you missed the point
Old Aug 12, 2009 | 12:07 PM
  #70
Well... we could arrange something for stock 4th vs stock 5th... should've been done at Maxus but eh too late.
Old Aug 12, 2009 | 01:13 PM
  #71
Kevlo911's Avatar
Kevlo for President
Ummm this has been discussed alot with track times and all. Search. Why should I keep this thread open?
Old Aug 12, 2009 | 04:16 PM
  #72
Apparently many that have commented in this thread never participated in the steamed discussions lol, I never even considered asking myself the question and figured the 5th gen would automatically be a little faster stock for stock but never knew it'd be just as quick..
Old Aug 12, 2009 | 05:41 PM
  #73
QNO_A32's Avatar
http://forums.maxima.org/1-4-1-8-mil...axima-run.html
ill lock it up with any de-k 5th gen with a short ram.
Old Aug 15, 2009 | 12:16 PM
  #74
maxed_out_99's Avatar
will the 00-01 vi bolt direct to a vq30de aside from the harness or is there more fabrication needed
Old Aug 15, 2009 | 12:50 PM
  #75
shadyonedeath's Avatar
shame on you.
Old Aug 15, 2009 | 04:46 PM
  #76
pmohr's Avatar
No more Maximas...
Did you even consider searching?
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
tgreen
Aug 27, 2015 08:34 PM
wellz
Aug 26, 2015 09:05 PM
criminalslang810
Aug 9, 2015 03:35 PM
