RPM drop at stop
Old Aug 10, 2009 | 09:02 AM
packerZ's Avatar
RPM drop at stop
I have a 96 w/ 5speed...lately, the rpms drop rapidly when I take out of gear right at stop. If I take out of gear way before stop and coast up, there is no problem. Sometimes, if RPM drop is too quick, it will stall...but usually it just drops below 500RPM and pulls itself back up to about 750/800 (normal idle w/AC)without stall. NO issues on idle or takeoff. Is there an idle stop/throttle cable tension that needs ajustment?? This just started a coupla weeks ago and car runs beautifully otherwise! Small, but irritating, problem. Thanks y'all
Old Aug 10, 2009 | 09:13 AM
B_Eaze's Avatar
whens the last time you clean your IACV and TB? I think its time.... Then adjust the screw at the top to the correct RPMs
Old Aug 10, 2009 | 09:35 AM
MOHFpro90's Avatar
Lets see... it stutters when you start idling... idling... hmmm... IDLE air control valve maybe?
Dont adjust that screw on the top.
There is a small screw that does control the throttle plate stop position. I wouldn't touch that until I was sure that was the problem. Might be like putting a bandaid on the broken arm.
Old Aug 10, 2009 | 12:02 PM
pmohr's Avatar
No more Maximas...
OP: As said, check and thoroughly clean the IACV and TB, and properly adjust your idle. 800 is a bit high.
And you never want to touch the throttle plate stop screw unless absolutely necessary. In most cases you never have to, not without some serious modifications. You are supposed to use the black plastic idle adjust screw on top of the IACV.
Old Aug 10, 2009 | 01:31 PM
DBear's Avatar
I had a similar problem. Replaced my Autolite plugs with NGKs and all was good.
Old Aug 11, 2009 | 06:13 AM
packerZ's Avatar
Thanks guys! Looks like I will doing some research on cleaning IACV and Throttle body!! The plugs are Platinum NGK's .
Again, thank all of you for your input and sending me on the right path, any quick links to TB/IACV cleaning before I begin search process?? Doug
Old Aug 11, 2009 | 06:27 AM
Nozama's Avatar
Grumpy old guy
http://forums.maxima.org/4th-generat...on-maxima.html
Old Aug 11, 2009 | 07:03 AM
nismo lover's Avatar
gotta clean the tb plus if u have an intake on there clean it or change it.
Old Aug 11, 2009 | 08:35 AM
packerZ's Avatar
Great link!! Thanks, Nozama!
Old Aug 12, 2009 | 05:48 AM
JtzMax's Avatar
Whatchyou say?
I'd also check for a vacuum leak .... I know this is a 'somewhat' common problem for us 5spd guys .... at least I know of it happening to a few members, myself being one of them. I cleaned / checked everything ... was no change. Mine was acutally worse though ... would stall if in 'N' and coming to a stop, but not in gear. Dunno ... but, I did find that my CAI plate had come apart and left a gaping hole. Once I fixed that, hasn't done it since. So ... something to check. Now that I've jinxed myself here ... I'm gonna quit.
Old Aug 12, 2009 | 09:37 AM
Sounbwoy's Avatar
I cleaned my TB thoroughly and all was good.
Old Aug 12, 2009 | 02:25 PM
mahanddeem's Avatar
How should I do that setting on TB ? I have the exact same issue
Old Aug 12, 2009 | 06:30 PM
pmohr's Avatar
No more Maximas...
The one I specifically mentioned that you should not touch? Just play around with it, you'll see how it works. Good luck ever getting it back to the factory setting, though.
Old Aug 12, 2009 | 08:50 PM
DAVE Sz's Avatar
Hooooooonda.....
MAF sensor....
Old Aug 12, 2009 | 10:18 PM
cfiggs's Avatar
have you searched? I know theres a lot of people with this common problem, I had a similar problem to this and I ended up needing a new iacv, but you will get a code, i believe even if it just needs a cleaning. Also your idle, when it doesn't drop and stall out where does it sit? does it only happen when you push the clutch in and then recover? i used to tap the gas a little when i pushed the car into neutral and that kept it from stalling until you find your problem.
Old Aug 13, 2009 | 10:48 AM
JtzMax's Avatar
Whatchyou say?
Sorry to change the subject ... but I gotta ask :
cfiggs .... your 93' Camary - how much was that 200 hp paint job? Did it make it go fast? LOL
Old Aug 13, 2009 | 02:15 PM
mahanddeem's Avatar
you scared the chit out of meee........I'll never think about touching it...
Old Aug 14, 2009 | 06:17 PM
cfiggs's Avatar
5bills i got that high quality window chalk and did it myself
Old Aug 16, 2009 | 01:14 PM
JtzMax's Avatar
Whatchyou say?
^^^^ I think you missed the joke here totally!
Old Aug 16, 2009 | 01:41 PM
ampire's Avatar
^or you did? window chalk huh?
Old Aug 16, 2009 | 02:49 PM
JtzMax's Avatar
Whatchyou say?
:matt93se:
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
maxima-junky
Oct 7, 2015 06:13 PM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
