Hard starting, extremely hard and black smoke
Old Sep 22, 2009 | 12:46 PM
  #41
BeZerK2112's Avatar
Well if your doing the 3.5 swap isn't that a new engine and electrical? Shouldn't have any problems in the long run.
Old Sep 22, 2009 | 01:22 PM
  #42
Crusher103's Avatar
not really its going to be a 3.5/3.0 hybrid, or a 3.5 with 3.0 timing, either way alot of stuff is going to be reused
Old Sep 22, 2009 | 01:35 PM
  #43
Originally Posted by oVeRdOsE
First sorry, Im working I have no time to read your post, I hope it can help you, I really understand your feeling about this problem....
After doing everything on this board, my car did like your.
What I did (and it worked!!) : unbolt what you can of the tranny screws. Sand all the galvanized stuff on it. Try to sand the inner filet too.
Use diaelectric grease and put the srews back.
Hope its a new answer... lol . Cost nothing.
good luck
fu(k it, no mather.
What I mean, just grind srews holding the tranny to the engine block. (to get a better electric flow)
If it's a grounding issue (which I doubt), he could reground the tranny with any cheap ol' wire (Ptatohed used a thin speaker wire and it's been working fine for years now) . This is much, much easier than what you described and would accomplish the same thing.
Old Sep 22, 2009 | 01:51 PM
  #44
Crusher103's Avatar
i installed a grounding kit a couple of weeks ago so aswell as clean some of them, i doubt my grounds are the issue
im going to try another ignition switch and see if that solves anything tomorrow, i already have the dash pulled apart
Old Sep 26, 2009 | 07:18 AM
  #45
Crusher103's Avatar
got another ignition switch installed it and no dice, any more suggestions, BTW im not throwing any codes, ive just about had enough, the car is getting ready to go to nissan to find out the problem but i would like to avoid their *** rapage for diagnosis.
Old Sep 27, 2009 | 01:25 AM
  #46
MoncefA33's Avatar
3.5 swap
Old Sep 27, 2009 | 07:02 AM
  #47
slow_yota's Avatar
good luck
wtf ??
Old Sep 27, 2009 | 08:07 AM
  #48
96WhiteMaxima's Avatar
Check your camshaft sensor, one of the wires in mine was frozen and I had that starting issue where your car cranks, makes a small pause and then cranks again and starts. I replaced the sensor and the car works like a champ now.
Old Sep 27, 2009 | 08:11 AM
  #49
Crusher103's Avatar
the thing about it is wouldnt the crank sensor throw a code?, im not throwing any.
Old Sep 27, 2009 | 10:25 AM
  #50
Manually check for the codes, maybe you have an old code lying around somewhere, idk man, its worth a shot, see if you can pick one up cheap somewhere.
Old Sep 27, 2009 | 10:31 AM
  #51
shawn's maxima's Avatar
CHANGE UR COIL PACKS. THIS SAME THING HAPPENED TO ME
Old Sep 27, 2009 | 07:24 PM
  #52
Leo_Koneval's Avatar
Hmm... wow your car is still having problem? I remembered thinking, YES we have solved another problem, but I guess, not?
But from what you posted, your starter is still spinning even though you took the key out. Which means that somehow it is still getting power, that is not from the ignition switch.
I wish I could just drive over to your house and see this for myself because I am having a hard time visualizing all the little parts and stuff in our cars, but I think there was another member a while back who had the same mysterious issue, where the car would keep running after the key was out.
Old Sep 27, 2009 | 10:58 PM
  #53
Crusher103's Avatar
its sooo annoying, i think a relay is to blame in this scenario actually but is there a starting relay? i havent seen one yet.
02PearlSE
Oct 7, 2015 02:12 AM
305head
Aug 26, 2015 09:03 PM
FlaMark
Aug 21, 2015 11:06 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
