Crank, no Start. Replaced fuel pump already..possible alarm problem
Old Sep 2, 2009 | 11:53 AM
eckounltd287's Avatar
Likes them corn fed
Ok,
So my father changed his gas filter and for some reason disconnected two tubes that go into the airbox area.
Well now it does not start.
we took it to a mechanic and replaced the fuel pump..i think its a issue with the alarm.
is there any way to varify if its the alarm.. We disarmed the car and still no start,
It keeps cranking but wont turn over. the battery is good.
Old Sep 2, 2009 | 12:05 PM
aackshun's Avatar
Did you recconnect the tubes? Unplugged vacuum hoses will cause your problems...
Also what year do you have?? If it was a 99 w/ the awzum NATS then it wouldn't crank if it was an alarm issue...
Old Sep 2, 2009 | 12:09 PM
Likes them corn fed
It is a 99.
yes the hoses were put back immediatly
what is this "Nats"?
Im going to make sure it's cranking. its my fathers car and im gonna go check it out.
Old Sep 2, 2009 | 12:14 PM
aackshun's Avatar
A chip in your key that's matched to uhh ecu I think, but either way if there was a problem with the NATs i'm pretty sure the car wouldn't crank at all.
Anyways, I'm out of bright ideas. But this does not sound like unique incident, there are dozens of threads with the same exact problems you're having, I would try another search.
Sorry for not being any better help .
Old Sep 2, 2009 | 12:39 PM
Nopike's Avatar
If it's cranking then there is no problem with alarm system. If the starter is over 10 years old, like mine was, remove it and have it tested. i recently went through something similar. http://forums.maxima.org/4th-generat...ike-champ.html
Lesson learned is, if your starter is more than ten years old and you have starting issues there is a good chance they are being caused by the starter. Had I know that the starter was so (relatively) easy to remove I would have gotten it tested.
Old Sep 2, 2009 | 12:46 PM
mahanddeem's Avatar
Originally Posted by eckounltd287
Ok,
sorrry,off topic....what was the problem with your muslem friends ?
Old Sep 2, 2009 | 12:52 PM
Likes them corn fed
** Update **
it Cranks.. Attempts to start..
After 5 seconds of attempting to start the security light comes on...
appearantly the mechanic checke all the electrical components, changed the fuel pump.. and checked the starter..
i'm going to go see the car today. any suggestions on how to fix it?
Old Sep 2, 2009 | 12:53 PM
Likes them corn fed
it was a quote from T erv T back about 2 or 3 years ago..
Old Sep 2, 2009 | 01:31 PM
pmohr's Avatar
No more Maximas...
Incorrect. NATS has nothing to do with the starter circuit.
It is a 99.
NATS == Nissan Anti Theft System.
** Update **
Does the security light stay on with the key in the ON position?
Are you using a 'real' key, or a hardware store duplicate?
It may be in lock mode, try the reset.
Failing that, you're in for a tow to the dealer for reprogramming.
Old Sep 2, 2009 | 01:48 PM
Likes them corn fed
how do i reset the alarm?
Old Sep 2, 2009 | 01:54 PM
pmohr's Avatar
No more Maximas...
As has been said, if it cranks, then the alarm has nothing to do with it.
However, if you're referring to getting out of NATS lock mode:
Any answers to my other questions, or...?
Old Sep 3, 2009 | 06:10 AM
JtzMax's Avatar
Whatchyou say?
Possible it could be a CKPS or CKPS Ref sensor as well. Are you sure the filter was not put in upside down? It should only allow flow one direction.
Old Sep 3, 2009 | 08:01 AM
njmaxseltd's Avatar
NATS lock mode? I learned something new today!
Old Sep 4, 2009 | 09:31 AM
Likes them corn fed
SOLUTION
REPROGRAMMED KEYS
103 BUCKS AT NISSAN
kjlouis
Nov 24, 2018 06:09 AM
conansriver
Sep 3, 2015 06:38 AM
homewrecker
Aug 24, 2015 08:56 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
Balkins
Aug 12, 2015 06:39 AM
