Brake Light On Intermittently
Hey Guys,
The last three mornings I have come outside to my car and driven to work with the brake light illuminated, even though the parking brake is disengaged. What gets me is that it goes away after driving to work (its gone at lunch, driving home, etc) and the fluid level appears to be normal.
Any ideas? This is just one of the many issues my car has been giving me lately.
Thanks,
Matt
Thanks,
Matt
maybe it might have to do with you brake light switch, but than again that only illuminates your taillights, or the harness which feeds into the master cylinder is loose try cleaning it and tightening it.
You say with the parking brake disengage.....did you have it on all night? If so, there is a switch that may be gummy and not springing off right away. It goes off and then you set it again that night only to have it happen all over again the next day.
Lyle
Lyle
Your brake fluid is low in the reservoir. Put a tiny bit of brake fluid in the reservoir OR change your brake pads and it will go off. When your brake pads and fluid start to heat up and expand from the friction of driving, the fluid gets just high enough to turn the light back off.
guaranteed
guaranteed
guaranteed
guaranteed
Makes complete sense though, I'll just add a small amount. DOT 4 correct fluid, correct?
Hey Guys,
Thanks,
Matt
Thanks,
Matt
It should be off of the master brake cylinder on the driver's side. The brake cylinder is mounted to the firewall. There is a clear plastic reservior with a max cold and max hot line on it. I cannot post pictures or I would attach one.
ok thanks. i saw that earlier and thought it was it. seems to be enough fluid. i dont know why my brake light is on. could be just a sensor/light malfunction. any ideas?
Is the fluid to the max hot line when your engine is up to temp?
The only other thing I can think to check is an electrical connection for the fluid sensor. I don't know much about this, but I do know there is an electrical connection for this somewhere. If there is a watertight plug somewhere near the reservoir. Please, if there are any other .orgers that know more about the electricals of the brake system, please chime in.
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
