Loose wheel lug
Old Sep 6, 2009 | 08:35 AM
holymoly's Avatar
Loose wheel lug
Seems that when I had mechanic change the lower control arm on the driver side front side, he must have cross-threaded one of the 5 wheel threads so that the wheel lug does not tighten securely.
Question is this a situation that deserves no attention, or should I need to go to a scrapyard and change the whole wheel splindle if that is was it is?
Old Sep 6, 2009 | 09:01 AM
B_Eaze's Avatar
You can buy studs individually at autozone for like $2
no searching ?
http://forums.maxima.org/4th-generat...heel-stud.html
Old Sep 6, 2009 | 09:36 AM
Conrad283's Avatar
I need a truck
Just change the stud if you're worried.
Old Sep 6, 2009 | 02:30 PM
holymoly's Avatar
Thanks for the link.
So just bang the bad stud out? why put the wheel lug on first and then bang?
Old Sep 6, 2009 | 03:48 PM
pmohr's Avatar
No more Maximas...
Just hammer it out, no need to put a lugnut on it. Their advice was most likely to avoid mushrooming the head of the wheel stud (at which point it wouldn't fit through the hole in the hub) but if it takes you that many hits to get it out, you'll likely need to press it out anyway.
Same reason you don't beat on the end of an axle, I've seen quite a few mushroom out that way and have to be ground down to fit back through the hub.
Old Apr 29, 2010 | 01:28 PM
holymoly's Avatar
OK, the second lug won't tighten, so now I have no choice but to replace both studs.
I just changed my pads today and noticed that one can pound them thru but not enough clearance at the other end to pop it through. Just looks that way.
So just bash it out?
Old Apr 29, 2010 | 01:47 PM
holymoly's Avatar
Now here is an illustration to tighten it
http://www.youtube.com/watch?v=gy9t1mU0lG0
But getting the old one out....
Old Apr 30, 2010 | 07:28 AM
holymoly's Avatar
*Bump*
To remove the studs, there doesn't appear to be the clearance of the head.
Do I need to remove the outer wheel bearing and/or hub?
Old Apr 30, 2010 | 07:51 AM
RAZ76's Avatar
That's what happens when morons that don't know how to properly use air guns. Get a new stud and lug.
There should be a slot on the back where the old stud can clear and come out. Keep spinning the hub until you find it. You know how to install the new one right?
Old May 2, 2010 | 06:21 AM
holymoly's Avatar
That's right, spin the wheels to a clearance spot. Took it to a garage and was informed the wheel lugs were damaged not the studs. They wanted $11 each, I said no, had the 99 cents ones at home.
Anyways saw how they installed lugs, no hand screwing, just jamming the lugs on.
Old May 2, 2010 | 07:40 AM
RA030726's Avatar
I'm nutty for Nissans
You have to take off the caliper,torque member and then the rotor to get the studs out.
Old May 2, 2010 | 09:28 AM
omoran2958's Avatar
you can put a piece of wood and hammer the stud out! then put the new one on,put a lug nut on and tighten it until the stud is all the way in....
viperboy
Sep 27, 2015 07:05 PM
Junebug1701
Sep 25, 2015 01:54 PM
BrandonCause
Sep 14, 2015 10:41 PM
dcam0326
Sep 8, 2015 11:02 PM
