replacing speakers
replacing speakers
im running the stock bose speakers in my 96 maxima. the tweeters are going bad and i want to replace them. can i just swap out the speakers or will i have to get into getting new amps, speakers, deck, etc?
I keep reading the stock Bose is a PITA when it comes to keeping the Headunit running.
If you want to keep the Bose.....try going to a junkyard...should be able to find cheap replacements.
I recommend checking this site: http://www.onlinecarstereo.com/ I got a set of Apline components for the front and a set of two-ways for the rear deck for just over a couple hundred. The shipping was fast and the speakers were well protected. Haven't switched since.
Oh yeah, if you go the aftermarket route, you should be able to used your stock tweet locations with minimal mod to the door panel.
i guess what im saying is i want to do my modding in stages. i want to put in aftermarket tweeters, then front speakers, then rear speakers, then amp and HU. can i do that or will aftermarket tweeters not run bose wiring?
I will say you are going to get better sound with a separate 4-channel amp. I recommend running separate wires because the stock wiring is not the thickest gauge and will pick up noise from the engine bay (at least this was my experience with my other cars. I have installed about 10 systems and if you need some advise, please hit me up for info.
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
