anyone change their 95-96 airbag and steering wheel to a 97-99?
Old Oct 20, 2009 | 11:02 AM
happy4444's Avatar
I did and now the airbag light's flashing. everything bolted up fine and went smooth. i disconnected the battery currently in hopes of the ecu resetting itself but has anyone else had this problem and how did you fix it? thanks
nick
Old Oct 20, 2009 | 11:13 AM
JNCoRacer's Avatar
Just the tip.
I didnt have any problems when I did mine. Did you have the battery disconnected when you were changing everything out?
Old Oct 20, 2009 | 11:17 AM
happy4444's Avatar
kinda forgot :/
Old Oct 20, 2009 | 11:18 AM
happy4444's Avatar
ill try resetting the ecu manually by turning the friggn screw
Old Oct 20, 2009 | 11:51 AM
JNCoRacer's Avatar
Just the tip.
Originally Posted by happy4444
kinda forgot :/
You got some ***** man.
I highly doubt resetting the cars ecu will do anything to help. But try this...
Open the driver's door. Note the rubber covered button, a button which is
pressed by the door when the door is closed. This is the Driver's Door
Switch (DDS).
Turn the ignition from OFF to ON. Press the DDS at least 5 times within 7
seconds after turning the ignition switch ON. Turn the ignition OFF.
Close the driver's door. Start the engine.
Old Oct 20, 2009 | 11:59 AM
happy4444's Avatar
no luck FML
Old Oct 20, 2009 | 05:58 PM
pmohr's Avatar
No more Maximas...
Have you read the code, to see what exactly it's complaining about?
The ECU has nothing to do with the airbag light.
trasmadean
Feb 1, 2017 08:20 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
tnewbs
Aug 28, 2015 10:15 AM
Flores94
Aug 13, 2015 01:17 PM
Flores94
Aug 11, 2015 12:53 PM
