Battery being drained even after alternator replacement
Old Jan 9, 2015 | 02:59 PM
  #41
pmohr's Avatar
No more Maximas...
Originally Posted by MonsterMaxima
What do I do to fix this problem? The battery light in the cluster does not stay on with the key in the ON position like the other lights but it does turn on for a split second then turn off making me believe the bulb is still good.
Unplug the alternator and see if it stops turning on at all. If so, ground pin 2 (W/R wire), and see if the bulb stays lit.
If so, it's an alternator problem.
Old Jan 9, 2015 | 10:23 PM
  #42
KP11520's Avatar
First, the only alternator I'd put in is a Bosch (and I did). Yeah expensive. Not a fan of those "Chains".
Second, after 16 to 20 years old, I'd just replace this with the alternator or those with undiagnosed problems if the alternator is still good: http://www.ebay.com/itm/NISSAN-MAXIM...6cac3e&vxp=mtr
I hope this helps!
Old Mar 12, 2016 | 09:26 AM
  #43
hardrookie's Avatar
I have a 1999 model Nissan altima. I replaced the alternator now none of the controls on my doorare working, the alarmwill not activate and once I turn on head lights the battery drains dead after about 5 minutes. Replaced the alternator twice with the same problem each time.
Old Aug 29, 2023 | 01:40 PM
  #44
Tcagle_5's Avatar
New altonator new battery still lossing power
I have a 6 gen Max and I have changed my battery and altonator amd car won't run longer than 20 min
Old Aug 30, 2023 | 11:15 AM
  #45
JvG's Avatar
JvG
The Maxima forum is organized by generations.
This is the 4th generation section.
Our cars differ from yours.
You need to post in the 6th generation section.
members there will be more familiar with your problems, and how to fix them.
Old Aug 31, 2023 | 06:13 PM
  #46
Tcagle_5's Avatar
Thank u
Jake91s
May 11, 2014 06:45 PM
teeezmaxSE
Aug 24, 2005 08:42 AM
shadygrey
Jan 14, 2004 03:48 PM
nigfink
Nov 23, 2003 01:01 AM
1MAX2NV
Aug 27, 2002 05:56 PM
