help replacing serpentine belt.
Old Jan 15, 2010 | 10:14 AM
eFLO's Avatar
so i yesterday i set out to replace this damn belt, i proceed to loosen the nut on the pulley, then adjust tensioner bolt up above, manage to wrestle the old belt off but i cannot for the life of me put this new belt on, or the old one either. now i've read of the adjustment bolt actually breaking if you loosen it too far, my question is how far can it actually be turned? will i know if i'm about to break it?
i need some tips! thx
Old Jan 15, 2010 | 10:46 AM
DTrem08's Avatar
Try wiggling/pushing the idler pulley up while trying to slip the belt over it.
Old Jan 15, 2010 | 10:52 AM
ATTappman's Avatar
I don't think it will break off. The pulley should loosen up so much that you can pull it up with your fingers, and it fact it won't stay up unless you tighten the adjuster nut a little.
If nothing else works, put a socket on the crank pulley and turn it clockwise to walk the new belt on. But this shouldn't be necessary.
Old Jan 15, 2010 | 05:48 PM
jazznorman3's Avatar
Well this is how I was able to replaced my, sence the person I purchase my car from, had already damage the tension pulley. placed the the belt over the crank shaft pulley or harmonic balance and the idle pulley, now here is the tricky part, placed an 3/8 socket on the the harmanic balance nut and gently turn, as you turn use a flat head srew drive and guide the belt over the AC compressor . good luck
Old Jan 16, 2010 | 08:31 AM
eFLO's Avatar
thanks guys,
just an update i was able to get it done, just kept loosening the tensioner carefully, and was able to slip the belt under the idler pulley. while i was working under there i noticed some coolant dripping... that'll be a another task. woot! lol
Old Jan 16, 2010 | 09:47 AM
ineedamaxima's Avatar
Hey eFLO, what mileage you at?
Old Jan 16, 2010 | 10:01 AM
DrivenToTheMAX's Avatar
This happened to me once. I had to losen the AC compressor so I could get the belt on then I was able to put it on. Don't recommend leaving the bad tensioner pully as it will start to squeel, especialy when you start the car. Idler pullu is around $26.
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
