Brake Light Problem!!! PLEASE HELP!!!
Old Feb 23, 2010 | 07:57 AM
mpvibes's Avatar
I have a 98 SE, the right inner brake light does not work, only when I hit my brakes @ night when my headlights r on, all of the other lights work except for this one. Its funny though, because the brake light comes on when I hit the brakes during the day time when my headlights r off. I know its not the bulb because I changed and swapped the bulb (1167LL) into the other brake lights and they work fine. I got a ticket for this last friday from a ***** COP, and I have to go to court for this B.S., and I need to get this fixed!!! PLEASE HELP, ANYBODY!!!!
Old Feb 23, 2010 | 08:15 AM
cashoit's Avatar
I would trace wiring to the bulb. Use a mulimeter and check voltage at light harness. Then try to trace the wire back into the wiring harness.
Old Feb 23, 2010 | 11:37 AM
mpvibes's Avatar
Ok, I will use a multimeter and test out the 2 wires for that particular side. Thx.
Old Feb 23, 2010 | 08:21 PM
Nopike's Avatar
You should measure about 12VDC at all the the red/green wires for the brake lights when you step on the brake pedal. If not you have a bad connection.
Old Feb 23, 2010 | 08:47 PM
cartman854's Avatar
pull back the inner cover of the trunk, check bulb, check wiring, unplug, plug back in, most likely fixed, if not, call your local wireless provider. Lol jk, that might fix it, but if it dont, refer to first 2 posts after the opening one.
Old Feb 24, 2010 | 02:42 AM
ajm8127's Avatar
It's also possible to read 12v at those wire relative to ground but your light won't light up because of a bad ground restricting the current flow.
I would make sure you have a good ground connection from the base of the bulb socket to where ever it grounds to.
Old Feb 24, 2010 | 11:39 AM
mpvibes's Avatar
Ok, thx everybody. I will check it out this week.
Old Feb 27, 2010 | 03:22 PM
mpvibes's Avatar
Yeah guys, I checked the current flow of electricity and its low. I believe its the part where you insert the bulb in, has gone bad. What do u call it again? Anyways I went to the stealership and they were charging me $48 for the part. It comes with the wire harness along with the female connector. Can someone please tell me the exact name of this part, so that I can either look for it on ebay or @ a junkyard? Im not paying
$48,THX.
Old Feb 27, 2010 | 09:15 PM
Trini Boom's Avatar
PM maxfever1987. He should have them for a reasonable price.
Old Feb 27, 2010 | 10:01 PM
anomaly117's Avatar
easy solution to avoid ticket, remove both bulbs from you inner taillights, so only the outer section lights up, perfectly legal, and...
MAD JDM YO
Old Mar 2, 2010 | 08:38 AM
mpvibes's Avatar
Ok guys I finally got the brake light working!!!! After going to 3 different junkyards I found the part I needed and everything works fine. The part is called "pig tail brake light harness", it is located on the back inner tailight of the trunk, it controls the function of the brake light and the reverse light bulb; you can only get it @ a junkyard or the stealership. I got it for $5 @ the junkyard off of a 97 maxima. No more issues now, thank God and thank you all for helping me out.
Old Mar 2, 2010 | 08:44 AM
cashoit's Avatar
nice!
I love updates and happy endings
Old Jul 3, 2015 | 06:11 PM
Shannon and Ian's Avatar
Bump for Google Search and the forum. I am having this exact problem with my left side inner and the key was testing the brake light with the headlights off. It works but is not as bright as the rest. Headlights on the inner does not work. I am going to assume it is the harness as well and source one from a junk yard.
Old Jul 3, 2015 | 06:39 PM
JvG's Avatar
JvG
I deal with corroded contacts a different way I wraps a small piece of sandpaper around the eraser end of a pencil, then use that to lightly sand the corrosion off.
Some electrical contact cleaner from the parts store helps too. I. have used brake cleaner as well.
My method works, it fixes most issues right away. I save lots of time and some money.
dim bulbs usually mean corroded grounding wires.
Old Jul 6, 2015 | 07:30 AM
Replacing the pigtail did the trick, thank you!
Old Jul 6, 2015 | 11:34 AM
nissan99's Avatar
Always hit the junkyard for stuff like this... Funk the stealer ship
Old Oct 13, 2018 | 10:58 AM
Bump. Last year I had to do this for my right side inner tail light and now my right outer is doing this. I only pulled this thread to see which one it was I originally changed. Looking for an outer pigtail now.
cabernet
Jul 19, 2011 05:27 PM
95 Maxnout
Apr 27, 2007 01:18 PM
2k2nyc
Apr 15, 2005 03:18 PM
jay8101
Nov 25, 2004 07:31 AM
zourtney
Aug 21, 2004 02:13 PM
