SO IT WASN'T A HEADGASKET!!!
Old Mar 20, 2010 | 09:59 AM
scmaxima's Avatar
alright my recent problem of the car overheating and leaking in no time wasnt a headgasket!
i just went to the mechanic and he took a quick look and in no time he said its a waterpump, and he said that when you change a waterpump you usually change the thermostat as well...
so i asked how much he said 550-600 lol
i got a paint job thats better than anything else out there for 190 bucks.. almost all the car except the doors and trunk!
anyways the parts online OEM are around 60 bucks. should i take it to another mechanic to fix it or just do it myself?
how long does it take and is it worth it or not?!
thanks
Old Mar 20, 2010 | 10:48 AM
Vaudeville Villain's Avatar
Old Mar 20, 2010 | 10:52 AM
scmaxima's Avatar
Originally Posted by Vaudeville Villain
so youre not gonna help
Old Mar 20, 2010 | 11:39 AM
RA021526's Avatar
Hahaha! That was a burn AND it involved Star Trek! Awesome.
Anyway, a quick look at the how-to section would answer your question. Also, if you look through your FSM you'd know how easy it is to change your thermostat. The water pump is in the FSM too.
Have a good day.
PS. You'll have to change your oil and get new coolant. It's up to you whether or not you want to do the thermostat. Your mechanic might have just been saying you need to do it.
PPS. That being said, it might be that your thermostat is stuck closed and is causing your engine to overheat. I'd do both, if it were my car.
Old Mar 20, 2010 | 12:02 PM
scmaxima's Avatar
Have a good day.
yea true.. both parts are so cheap so its worth doing them...
and i know how to do the thermostat myself... just not the water pump 0.o
im asking on nycmaximas to see if anyone can help lol
Old Mar 20, 2010 | 03:03 PM
RA021526's Avatar
Old Mar 20, 2010 | 04:42 PM
mightyMax95's Avatar
first, what was the necessity in creating another thread for the same issue? second, didn't i say it could be done at home? i believe so.
check the how-to's, it's all in there. that's why they're there.
Old Mar 20, 2010 | 06:23 PM
Mr.A32ftw's Avatar
http://www.vqpower.com/v2/articles.php?article_id=68
Old Mar 20, 2010 | 06:31 PM
Trini Boom's Avatar
thanks
I hope that I am not the only one who finds this strange. I never heard of a water pump stopped working to cause your car to overheat. I know the thermostat can if it stuck closed. Was your water pump leaking? If not, I would start with the thermostat first which is alot cheaper than the $550 - $600 this repair man is asking you to shell out.
Old Mar 20, 2010 | 08:09 PM
B_Eaze's Avatar
That's because the OP created this thread to tell everyone his issue, which was already suggested in the old thread.
Old Mar 20, 2010 | 08:18 PM
scmaxima's Avatar
well i have both!!!
antifreeze leaks in like 10 minutes of the car running, and the car overheats..
so yea both problems i guess
Old Mar 21, 2010 | 11:52 PM
HandsonMaxima.'s Avatar
well you can tell if its your thermostat very easily. if when it overheats the top radiator hose is cold. your thermo is broken and replace it. easy.
change that oil pump while your in there. and your timing chain tensioner. both are cheap enough to do it while you have to cover off.
James92SE
142
Jan 2, 2024 09:23 AM
D Mason
Jun 21, 2016 04:43 AM
Junebug1701
Sep 25, 2015 01:54 PM
220k+ A32
Sep 23, 2015 03:38 PM
lrb6805
Sep 17, 2015 04:49 PM
