My new $225 GXE project car
Old Apr 20, 2010 | 08:16 PM
  #41
youngquazy's Avatar
Originally Posted by komik
$1400 for an engine? I paid $1400 for my SE.
yea but its most likely got some mileage on it right? my engine has 59,000 miles. plus its a GLE
Old Apr 20, 2010 | 08:18 PM
  #42
Str0mz0r's Avatar
After washing off four years of grime, the paint looks great!
(Picture)
The body is practically flawless aside from that one door, which, despite its condition, didn't let in any water when I washed it. I vacuumed the interior and it looks almost new aside from the carpet.
I haven't been able to do much this weekend. It rained on and off today and is supposed to rain all day tomorrow. So far I have disconnected most of the electrical connections on the engine, drained the oil, and removed the air intake, filter box, engine cover, UIM / TB / EGR, and coil packs.
Right now, the forecast for next weekend is looking good. I hope to put in a good amount of time on it then, because I'm going on vacation May 1.
Looks like a steal to me. Hope rebuilding the engine works out for you!
Last edited by Str0mz0r; Apr 20, 2010 at 08:19 PM. Reason: Picture made screen too big.
Old Apr 20, 2010 | 08:26 PM
  #43
komik's Avatar
Yes, my SE is pushing 260k. I just saw in another thread that your $1400 is parts and labor with a warranty. In that case, it's not a bad price at all.
Old Apr 20, 2010 | 08:29 PM
  #44
defiance's Avatar
Not bad! But you cant even try to beat the OP when it comes to the price your paying for that engine...UNLESS it a brand new crate motor.
Old Apr 20, 2010 | 09:24 PM
  #45
dtortor1's Avatar
Bought my current engine at a salvage yard for $750. I still don't understand how it could only have had 7000 miles on it back in 2002. Hmmm..
Great deal on the car. I'd give that much to be able to pull parts!
Dom
Old Apr 20, 2010 | 09:28 PM
  #46
CMax03's Avatar
Guaranteed a blown head gasket or cracked radiator....Dig in! Perform a compression test It can't be that bad! Also perform a coolant pressure test!
Old Apr 25, 2010 | 12:46 PM
  #47
komik's Avatar
I made an interesting discovery today when removing the LIM. Having sat for a very long time, the car has become home to a variety of creatures. When I turned the LIM over, I found a live creepy looking dark black spider. When I poked at it with a crowbar, it turned to reveal a red hourglass shape. For those of you not up on your arachnids, it was a black widow! ...was...
So the fuel tube / injectors, LIM, and rocker covers are now off. Next step is to get under the car and start working towards the timing chain case. Unfortunately my old 2 ½ ton jack does not quite have the range to get the car where I need it. The ground slopes downhill and I will have to get the driver's side a little bit higher up to level the car.
One of the four tabs on the #6 injector is broken off. I am not sure what effect that has on its performance, but it's going on the list of parts to replace anyway.
Where possible I am leaving nuts & bolts in place after removing the parts they secure. For the rest of them, scrap cardboard and a sharpie do a fine job.
I am going out of town for a week on the 1st, so buying a new jack, as well a puller for the crankshaft pulley, are going to have to wait until I get back. The project may be slow going, but at least it gives me something to wrench on after watching Powerblock each weekend.
Old Apr 25, 2010 | 01:11 PM
  #48
defiance's Avatar
Looks like that engine has been running with no oil for quite some time.
What do you plan to do when you find the real problem in this engine ?
Old Apr 25, 2010 | 06:04 PM
  #49
komik's Avatar
Originally Posted by defiance
Looks like that engine has been running with no oil for quite some time...
What do you mean? I drained a gallon of oil out of it last week. In the picture above you can see oil dripping over the edge where the gasket sits.
Old Apr 25, 2010 | 07:37 PM
  #50
defiance's Avatar
Just look how black it is makes me wonder if anyone ever changed it...
Old Apr 25, 2010 | 07:44 PM
  #51
aNtHoNyNoZ's Avatar
FIRST MOD would be to rip out everything a/c rear seats your name it weight reduction and drop a 3.5 in that hoeeee
Old Apr 27, 2010 | 09:14 PM
  #52
komik's Avatar
It is pretty nasty. The oil I drained out was the blackest oil I have ever seen. There is a good layer of sludge coating the valves. It smells pretty bad too. A friend of mine works in the machine shop at ABC Auto Parts. Once I get the heads off, he is going to thoroughly clean and resurface them.
Old Apr 27, 2010 | 10:25 PM
  #53
defiance's Avatar
So is the engine pretty much hydro locked ?
Old May 3, 2010 | 07:34 PM
  #54
philly96maxima's Avatar
..with all that sludge & which points too apparent neglect, is it worth rebuilding this engine ??
Old May 4, 2010 | 02:06 PM
  #55
95Maxed's Avatar
wow. 250 bucks, you lucky dog.
Old Feb 26, 2011 | 04:50 PM
  #56
komik's Avatar
Shortly after my last update I started travelling a lot and have had little time to devote to this project and after running the numbers some more I have decided to abandon it. For what it would cost me to fix / replace the engine and get the body work done I could buy another running Max. The GXE is now a donor car for my SE and will be sold to a junkyard when I'm done.
Today I swapped the steering wheel, driver's door interior handle / key cylinder / latch / connecting rods, sun visors, center armrest, front marker lights, center A/C vents / clock / flasher / defrost, glove compartment, and rear view mirror. I may paint the valve covers and UMI to put in the SE whenever I get around to replacing its valve cover gaskets. I'm going to keep some other parts (coil packs, alternator, starter) for spares.
Old Feb 26, 2011 | 07:29 PM
  #57
foamerdave's Avatar
I think this might be a smart move on your part
Old Feb 26, 2011 | 08:37 PM
  #58
beegeezy's Avatar
+1
No sense in dumping too much into a car that is of unknown quality. Still, you got a steal on a good parts car!
Old Feb 27, 2011 | 01:44 AM
  #59
silencecalls's Avatar
Imho 250 for a parts car is amazing! I paid 220 just for a transmission the other day. Not to mention you can keep the car, e-bay parts you are sure you won't need and you would have MADE money in no time!
Old Feb 27, 2011 | 05:16 AM
  #60
txsilverado1's Avatar
Oh well. I understand the logic of parting it out. However, my nature would have forced me to put a good salvage motor and door in it. Then put it back on the road and work out the bugs. I have a guy here local that would have sold you a complete running 125k motor with all accessories still attached for $300. Then snag the door from craigslist here in DFW for $100 or less. Add $200 in misc unknowns and for a grand total of $600+$250=$850, you would have had a good car.
Old Feb 27, 2011 | 11:11 AM
  #61
beegeezy's Avatar
But what about the autotragic in the car? Who knows if that things works at all?
Old Feb 27, 2011 | 11:38 AM
  #62
HomerMAC's Avatar
Donating i30 Owner
.. drop in a dek.. 300$ an engine.. my SC kit... in the FS section.. and your golden...
Lakersallday24
Jun 16, 2019 01:35 AM
schmellyfart
Sep 25, 2015 04:47 PM
Ray229Harris
Sep 16, 2015 08:16 PM
WeetoddA32
Aug 16, 2015 12:45 PM
MikesChevelle
Aug 9, 2015 11:50 AM
